Speed Queen AWN542 Washer Logo
Posted on Apr 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine goes thru the wash cycle then it stops, if I lift the door it starts again ,than stops. lift the door it starts than stops
fixrguy
Level 3:
  • Master 415 Answers
  • Posted on Apr 09, 2011
fixrguy
Master
Level 3:
Answers
415
Questions
0
Helped
82580
Points
1311
It could be your out of balance switch is getting tripped before you try it again put in the spin cyc and see if it spins and drains the water if it does a odd sized load could be causing the failure.
Maytag Neptune Model MAH5500BWW will start and one second later "door locked" light goes off and stops the wash.
The door switch and the lock for your door and the sensor that lets the door to be able to lock and start up is broken and should have to be replaced. for your washing machine
Water goes in it washes for little while then buzzer starts before wash cycle ends
Hi Gina,
When your machine stops during the cycle does it beep & hold some of the wash progress lights on?
This is how it displays where the fault is coming from.
The motor controller is the most common for this type of fault.
Thanks
Damien
Washing machine will not go thru full cycle. stops at part where wash water is drained, before spin and rinse cycle.
Check the lid switch. Open the door, It will be on your right, a lttle oval hole. I would start there.
How do i fix my washing machine interlock hotpoint hvf 344
The door should have a pin on it that pushes and closes the interlock switch. Check to see that the switch is inadjust ment to trip by turning off the water door open and with a plastic rod or a pencil push thru' the hole in the chasis where the door pin goes through and start the machine. If it starts quickly pull out the pencil, unplug the machine and adjust the switch. Plug it back in. It may continue on with the cycle you just started if not better! If not close the door aand start a short cold wash cycle. If it sounds like it wants to start, turn on the water and let it run thru' the complete cycle.
5helpful
2answers
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
[email protected]
2helpful
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Top Speed Queen Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
