SOURCE: Washer door won't open (hotpoint first editon 800)
I have just had exactly the same problem. 10 seconds of washing, fuse blew, replaced it, cycle completed but now the door lock is stuck on. Like you I tried a new cycle but this has done nothing. In the end (and I'm not suggesting that this a remedy to the problem) I unplugged the machine - pulled the door handle til a gap appeared at the top of the door and forced it open by working a pair of scissors in to the gap and pulling. Of course as soon as I shut the door again and turned on the power the lock light came straight back on the and the door was locked tight. Sorry but this is the best I have come up with short of calling some one out.
SOURCE: Door won't open
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
SOURCE: hotpoint aquarius wt540 wont pump out water
Hiya Barry, I have the same machine and for the last 3 days have had the exact same problem...mini load and reduced crease as well as power light flash right when it comes to drain...?
I have scratched my head and done lots and lots of research, reckon I could design and build my own washer now lol, anyway, I fitted a new pump and ran it, thinking this is it sorted, went out and got a call from our lass...doing it again.
Right, gonna have to get me hands dirty...I removed the drain hose (Ignore the pump for a second, I'm talking about the grey hose that goes from the pump to the sink) from the sink and poked my fingers as far as they would go...debris, I then removed it from the other end (Pump) so I had a long hose in my hands, not attached to anything at either end....cleared it and again, loads of debris (Fluff, plastic etc) and put it all back together...turned the old fella back on and running a wash right now as we speak...happily spinning round at 1400rpm and throwing gallons of water down the sink...I would consider it fixed.
So I can most definately tell you that you have a blockage somewhere mate, I'd get your hands in the toolbox and pull that pipe off, doesn't require any level of experience, just the ability to put things back as you found them...
Hope that helps
SOURCE: Broken door handle Hotpoint WD860
Managed to work it out, you have to slide the outer door case away from the handle locking mechanism, slide left and move away (after undoing the 6 screws on the inside) :-)
SOURCE: hotpoint wt540 can't get filter out
It is possible you have got something stuck in filter, and this is what is stopping it coming out, you are turning it the right way, you will just have to stick with it, and keep trying to ease it out.
Keep trying to eaes it in and out, and you should be able to remove it eventually.
Plz rate this solution.
Thanks.
