Compaq Presario 5000 PC Desktop Logo
Anonymous Posted on Apr 09, 2011
Press start button, fan trys to start, green light comes on then changes to a red flashing light
Anonymous
Level 3:
  • Master 961 Answers
  • Posted on Apr 09, 2011
Anonymous
Master
Level 3:
Answers
961
Questions
Helped
273409
Points
3003
If your fan is trying to start up but won't, your system is going to give you a warning and most likely shut down. Make sure you have good connection for fan power and that it is clean and can turn freely. You may want to cosider replacing the fan.
  • Anonymous Apr 09, 2011
    Check all you fans and heatsinks for operation and clean out dust and lint. If you do alot of gaming or run computer hard you may want to add a fan.
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Have a toshiba theatrewide hd dlp. Replaced the lamp because the led indicators suggested to replace. Now the same thing occurs. TV trys to start up. the green light flashes repeatedly while the tv...
Most likely a defective digital module which is part of the light engine and cannot be bought separately. The average cost to replace the light engine assembly is around $800.00.
2answers
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
Press on button but it clicks a dozen times before it turns on
If green and or red lights are flashing while the TV trys to start the lamp is burnt out, time to replace.
2helpful
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
1helpful
Zenith 56" DLP Z56DC1D won't turn on
Replace Lamp and CK both Fans to make sure they are running.If Fan behind Lamp does not run TV will not light LAMP.
Red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
2answers
Sanyo XU50 not coming on after lamp replacement
Hi oatesy13
You will have to reset the lamp timer to resolve the problem.
Consult ypour user's manual on how to do this.
Should do the trick , If you do however need any further assistance , please send me a request and I'll respond to it.
2answers
Computer does not start
Before we begin we?ll need some more historical information: -Was this a functional computer that just stopped working or is this something you?re building? -If this was a working computer were any new programs, hardware, drivers or updates anything that changed recently? -Have there been any recent error messages?
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
