SOURCE: Question for SanDisk SD card
There is a small switch in the card that is currently in the locked position. you need to move it over to the other position to unlock it.
SOURCE: Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
SOURCE: Canon powershot sd750 memory card files were
Did you forget to use the "safely remove hardware" function when you removed the card from the computer?
