Question about Philips 42PF9631D 42 in. Plasma Television
Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
TV is 1.5 years old. It's a Philips 42PF9631D/37 42" flat screen plasma. It won't turn on - just the red flashing light, seven times in a row, then it stops and cycles again, seven times in a row. Help, please!
  • 34 more comments
  • adrijo Oct 01, 2008
    42PF5321D/37
  • Anonymous Nov 16, 2008
    i have a 2006 42pf5321d-37 model number 42 inch phillips hd lasma it turns on for a second when the flashing red light turns green then it goes off & turns red and blinks slow four times then waits ect...
    barbieoutabox@hotmail.com
  • Anonymous Nov 17, 2008
    the tv wont cut on. the green light comes on than the red light cuts on and blicks 7 times terrenceproctor@aol.com
  • TomJudy592 Nov 25, 2008
    blinking red lite
  • t34gib Nov 27, 2008
    Just started, is there a solution?
  • dejavu624 Nov 28, 2008
    i have the same problem. my tv is 2 years old. it just started 3 days ago.
    the tv will not come on it just flashes a red light 7 times stops then starts again. can any one help looking for diagnostic code.
  • Anonymous Dec 03, 2008
    i have same problem
  • weimann3 Dec 04, 2008
    mine has started to do the same thing, last week I was able to unplug and re-plug it would be fine, now not so much. Interesting that they are all starting to do this at the same time. Can you say planned obsolescence?
  • sean8 Dec 08, 2008
    No power, only a red blinking light (7x). First time, i reset it (unplugged for a min. and then replugged it in) and it worked. A week later the same problem occurred and it didn't respond to the reset. I call phillips and they referred me to a customer repair facility.
  • batemanf Dec 13, 2008
    No power, a green light that turns red and blinks (7x) and than repeats. Has anyone found a solution to the problem. My tv is about 2 years and it is have the same problem as everyone else. Is there a solution out there, please help save some money. Thanks
  • atrain9591 Dec 15, 2008
    Same problem as the others.. will not turn on red light blinks 7x.. had a repair man out said the power board was out... cost to repair $551.00 parts and labor... :(
  • db1472 Dec 21, 2008
    I also have the same problem. Called Philips and the tech guy had me unplug the TV for about 30 seconds or so. Then I had to plug it back in and press the volume up button on the side of the TV as fast as I could. First time, the TV came on right away. Now it has turned into everytime I turn the TV off and back on after a length of time, I have to do the same thing. I have to do this 6 or 7 times now before the TV comes on. Just called Philips again and they told me to take it in...not sure I can afford another 500.00 to get it fixed!
  • Laurieval29 Dec 22, 2008
    I have the same problem. I know I can not afford do get this repaired at this time. This is horrible my kids are home for their Christmas break and we have no T.V.
  • Anonymous Dec 26, 2008
    I have same issue but mine blinks 8 times.
  • IronSights Dec 30, 2008
    Just to let you know, I have the same problem. I also unplugged the tv for a few minutes then turned it back clicking the up volume on the tv as quick as i good. TV stayed on, go figure! Definitely a manufactures defect!!
  • Anonymous Jan 29, 2009
    Blinks red seven times then recycles. Has anyone contacted consumerprotection. I'm contacting them tomorrow with complaint i suggesteveryone else do the same if you want phillips to repair this. It mustbe a common issue and they are aware of it . All products must betested before public release.
  • mikenealey Feb 08, 2009
    I have the same issue. TV will work for about an hour then shutdown and then show the 7 blinking lights. If I unplug the power cord for a minute then the TV will stay on for another 5 mins. If I leave it unplugged overnight it will last for an hour again. There was a solution on here about replacing capacitors, but do I need a service manual and if so where can I get one?
  • jeff_w38 Feb 14, 2009
    I have the same problem. TV is only 1 1/2 years old. green light comes on for awhile then starts to flash red. Sounds like Philips should do a recall. Anybody know of any recalls? jeff_w38@yahoo.com
  • Anonymous Feb 16, 2009
    I'm joining the ranks here. Mine started yesterday!!! I called Philips and they advised me to take it in for service. They don't even have a authorized service center in Wichita Falls, TX. I'll post what the repairs cost and the problem in the next week or so...
  • Anonymous Feb 17, 2009
    Dang it! There are a lot of us that have this same television and the red light blinking 7 times and yet no one has any type of solution... Whats up with that? Fixya is doing a great disservice to us all overall.
  • Anonymous Feb 18, 2009
    Same problem. No pic, seven blinks, recycle. See where computer parts used to fix. Need advise on what specific capacitors used, where to get, etc.
  • mustafe_8 Feb 24, 2009
    Hey guys there must be a catch here...we all have same prolem..mine started 4 days ago..when turning on it stays green for a second then turns into 7x blinking light. What is the problem..they could have told us that we should expect total of 2 yrs life expectancy on this ****...
  • Anonymous Feb 25, 2009
    I HAVE THE SAME PROBLEM BUT I TRIED LOOKING TO SEE IF ANY 2 CAPACITORS WERE BULGING OUT BUT I COULD NOT SEE ANY.
    my t,v is doing the samething how do i fix it
  • Anonymous Mar 01, 2009
    Same deal on mine. Doing research and this is widespread issue. No more Philips products in my house.
  • dwh20house Mar 02, 2009
    Same problem as everyone else.......because of the numerous complaints with the model can do anything about it? When I called Phillips, they were rude!!!
  • fredandgenea Mar 07, 2009
    I have the same problem with the light blinking red 7 times, can someone tell me were these (2) capacitors are located?
  • ITVENDING Mar 09, 2009
    HI FOLKS...I DON'T THINK THIS IS A NEW PROBLEM. JUST THIS MONTH 3/09) MY 42 INCH PLASMA...42FD9954 DID THE SAME THING. THE SET IS 5 YEARS OLD, BUT IT WAS ONE OF THE FIRST AND COST ME ABOUT 5 GRAND !...YES, 5 GRAND. I ASKED THEM, SHOULD A SET LAST MORE THAN 5 YEARS ? THE SET IS STILL IN A REPAIR SHOP (SECOND ONE) THEY REPLACED THE SIGNAL MODULE AND POWER SUPPLY TO AVAIL. ANY SUGGESTIONS ON WHAT IT MAY BE ???
  • fredandgenea Mar 10, 2009
    So would it be better to just trash the TV? I went to Sears the other day and they told me they discontinued the item because it caught on fire!!
    SO WHY NOT RECALL THE TV!!
  • Anonymous Mar 11, 2009
    Blinking Red Light in lower right corner of TV and the unti will not turn on. dammit.
  • Anonymous Mar 13, 2009
    Same problem. 7 red blinks. Makes me cuss everytime i have to keep unplugging and plugging to try to get it to come on.
  • Anonymous Mar 20, 2009
    Same thing Damn blinking light, When I called Philips they had no clue.
  • beatheman Apr 14, 2009
    I had the same problem as everyone on this board. my tv is about two years old and I had the same problem with the red light blinking seven times. I saw moldymacs comments and followed his advise. I opened my tv and noticed the two capacitors that looked bulged out on the top. they are side by side towards the bottom and are labeled 10v 3300uf. I went to my local electronics store and bought two for 1.20 then I took my board to my local tv/computer repair and he charged me 10.00 to remove the old and install the new capacitors. went home and reinstalled my board very carefully and problem solved. total cost was 11.20 and tv has been working fine....thank you moldymac you saved me a lot of money.
  • Anonymous Apr 23, 2009
    I have the same type of problem, but I only blink 6 times. Philips tech support is a joke!
  • calgappo
    calgappo Jan 10, 2013
    I would like to thank everybody who posted addressing this problem,I had to relace 6 capacitors (2 -3300uF 10V Radial Electrolytic Capacitors) and (4- 680uF 50V Radial Electrolytic Capacitors) TV works fine now.
  • Anonymous Mar 29, 2014
    My 55 inch Philips flat screen tv want come on can anyone help
    New Friend:
Philips 42
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
Posted on Dec 12, 2009
  • Anonymous Dec 12, 2009
    Here is a photo of one of the removed capacitors.
I had the same issue with 2 of these sets. It ended up being 2 capacitors were bad on the power supply. They are located towards the bottom of the board, you can visually see they were buldging and leaking slightly. I replaced them with 2 I salvaged out of an old computer (of same values) and the tv works as it did before.
Posted on Jan 08, 2009
  • Anonymous Sep 04, 2011
    what if the capacitors all look good???? this bites
We had this problem once before, tv lasted about a year before it started the 7x red blinking light , had it fixed, 500 some odd dollars to repair, now it started happening agian, same problem, just 7 months after original fail, so now we are going to go MoldyMac's way and look for the caps and see if a old computer can help supply the needed caps. There is a temporary fix to this problem if you need the TV now and not later, although it is temporary , because the problem just gets worse as the "capacitors" get worse. I imagine this may be tough for those who have the TV up on the wall. Stand to the right of the TV and you will see the power cord under it, which looks like a standard PC power cable , put your hand on this cord and get ready to pull it out, use the other hand to press the power button which is conveniently placed right where you are standing, the green light will come on and you will hear two clicks from inside the TV, wait a moment and you will hear another set of clicks that sound like the TV is shuting down, this is when you pull the power plug out of the tv by pulling and wiggling it out, wait for the Green light to go out, then plug it back in, it will attempt to start agian without you needing to do anything else to it, where you will here the initial two clicks, and then the TV should come on, if it didnt then repeat the process agian and agian till the tv starts. Thats my temporary solution, but remember the tv may start on the first try but will get harder to start each day.
Posted on Mar 10, 2009
  • Tubby Kubik Feb 03, 2013
    I have tried this with no luck. When I press the power off nothing happens just red lights continue to flash. Only way to get it to shut off is unplug and plug in again-if I hit the off button before the red flashing lights it will shut off? Am I doing something wrong?
Took moldymac's advice. Seven blinks/no pic. Checked capacitors, both bulged at top. Pulled connectors out of board (careful!!), pulled the main board out (do not drop screws!!) took it to local tv repair guy, he soldered two new, higher rated capacitors. Put board back in, plugged everything back up, bingo- back up and running. Heck with Phillips service centers ($500 is b.s.). $58.00 total repair bill plus my time. Something else may be a problem next week, but this sure fixed this problem today. Simple and cheap. Playing today with no problems.
Thanks moldymac!!
Posted on Feb 22, 2009
  • vincent cianci Aug 11, 2013
    Thanks you. Very helpfull.
TV is 1.5 years old. It's a Philips 42PF9631D/37 42" flat screen plasma. turns on for like 15 min then turns off then a red flashing light comes on, seven times in a row, then it stops and cycles again, seven times in a row. Help, please!
Posted on Sep 18, 2008
  • 3 Answers
MoldyMac,
Thank You! $62.00 and it worked perfect.
  • Anonymous Mar 12, 2009
    When you open your TV up you'll see the main board.
    Look at the two capacitors at the bottom(Side by Side). Yours may not be leaking yet but they will be swollen at the top. Take the board to your repairman and fix it. Mine is working fine!
    New Friend:
Hey, 9630 & 9631 Philips owners...we've helped fix a bunch of the problems on these plasma TV's besides the capacitor problem. Check us out over at AVS Forum, fix your TV set, see how many hours your plasma has been in use, fix the '4000 hour' glitch, etc.
http://www.avsforum.com/avs-vb/showthread.php?t=716082&page=31
Posted on Dec 21, 2009
The solution involving changing out the capacitors is spot-on. I had the same problem on Sunday, ordered the parts from digikey.com and had it in-hand by Wednesday. Now, with very minor soldering I am back in business. All told, it only cost $7.45 with shipping!!!
Posted on Sep 17, 2009
I HAVE THE SAME PROBLEM THE RED LIGHT BLICKS 7 TIMES
Posted on Nov 17, 2008
Did anyone who had this problem have problems with the screen before this happened? Our tv started losing the top half of the screen the other day, it goes white with different hues and the other half is fine. Turn the tv off and when you turn it back on it's ok for a while. Had it happen about 5 times in a hour or two and then not again for a day. This started about three days before tv wouldn't work at all and blinking light started. Just wondering if I fix this is my tv still going to need some other repair.
Posted on Feb 10, 2010
  • 1 more comment
  • sethmlanz Oct 01, 2010
    Well I just got home today and my TV wouldn't respond to anything. I think I have a different model than the one Muy has, but I'm not sure what model =/. however, it is mounted on the wall so it's too heavy for me to lift, but the red light blinks 5 times, and I'm not sure what that means. gonna have to live without the Xbox for a while *cry*
  • SKS27 Oct 07, 2010
    I had the same problem with the half screen and then last week the screen went blank with the seven red blinking lights. Any solutions, I've replaced the two capacitors and still hasn't solved the problem?>
  • Jeramie
    Jeramie Feb 20, 2011
    The vertical screen distortion is usually attributed to the Y buffer boards. There is a lower and an upper which control the vertical lines on picture. Typically when they begin to fail, you will see vertical lines and distortion in about 4 inch thich block patterns all the way across the screen. When both y boards go bad, you will see distorted vertical lines over the whole screen encased in 6 faint 4 inch blocks along with the lines. The blocks are lined up with the ribbon cable connections on the Y boards. There are 6 total and this is why the distortion appears in 6 faint blocks or less.
    Look at the part numbers on the boards and replace with exact matches. Be careful about buying other bad boards from ebay though. Try shopjimmy or discount-merchant as they back up there products.
    New Friend:
Can somebody offer a little more guidance about locating the capacitors? I've pulled the back panel of the TV, but I'm totally lost. Somebody said they're near the bottom -- bottom right, bottom left, bottom center? I didn't see anyting bulging or leaking, either. Thank you!
Posted on Nov 10, 2009
  • Anonymous Nov 10, 2009
    I posted a question on Solution #11. I found the capacitors... and yes, they were bulging, so no need to offer further guidance. Off to get replacements now. Thanks.
I have found that by using small space heater behind the TV for a short time before turning it on I am able to bypass the problem. Of course this isn't going to work if you don't have any space behind the TV. Might work if in general proximity but not sure. Good Luck. I'm not anxious to spend $500+ on a TV that's ~ 2 yrs old and costt $2000 to begin with. Seems to me there should be a recall.
  • 1 more comment
  • craigbowman1 Sep 18, 2011
    I did what u said small space heater behind tv for less than 5min. Bingo! Thanx.
  • MHarper Oct 14, 2012
    OMG! It works! Thank you!!!!!!!!!!!!!!!!!!!!!! I used a hot hand blow dryer. Wow!
    I heated back of tv with blow dryer for one minute (Through the venting). It actually worked. Thank you!
    New Friend:
I've done the capacitor fix and everything went great for about 6 months. Then, the same failure happened again.
I replaced the capacitors again (this time with a "better" part) and the fix only lasted 2 weeks before failing.
I'm ready to cut my losses with this TV and move on. It's a lot of money, but I can't have a TV that doesn't reliably turn on when I push the power button. Philips, I don't think that's too much to ask.
Posted on Jul 11, 2010
    New Friend:
Same problem here. While researching this online, I came across this link to an attorney who has filed a class action lawsuit. http://chimicles.com/case/magnavox-television
Posted on Feb 02, 2010
    New Friend:
Our tv was doing the same thing. Would not turn on and red light would blink 7 times. We opened up the back and low and behold there were the bulging capacitors. We took the mother board to our local tv repair shop and $70 later it is all fixed. Until the next thing goes wrong. Yahoo!! I would like to just put out there that there will NEVER be another Philips product in this house again! Thanks to everyone!
Posted on Nov 28, 2009
Awesome, I saw the bulging capacitors and came here after a google search. I knew they looked fishy, Geek Squad which came here on a warranty issue (unrelated) several days ago told me a repair would be about 500 bucks. Thats just off the top of his head w/o looking at it.
Future note, get the warranty at Best Buy its worth it, service is awesome.
Now I am going to get the 2 replacement capacitors and solder them in, I would rather have a tech do it but I didnt buy service on this one.
Thanks for the help I will update progress!
Posted on Nov 14, 2009
The problem is the Plasma Panel $1000.00 repair and Phillip knows about it .You can repair and replace everything on this tv . you will still have a problem somewhere else until you replace the Plasma Panel. There can be the same amounts of blinking ,but not everyone one has the same issue (figure that out ) A phillips repair center told me what the problem really is thank God for the honest people i suggest contacting phillip first get a complaint number from them and then contact consumer protection . like i'm doing . if it is going to get considered for recall this has to be done by all of us first .
Posted on Mar 11, 2009
    New Friend:
I had the same problem with the blinking red power light on my 42" Phillips. Went to this forum and read moldymac's solution and also saw a video on UTube of a guy fixing a similar problem the same way. I decided to chance it and ordered the 2 capacitors online. My buddy, who is more adept at soldering, helped me remove the old parts and solder in the 2 new capacitors. Plugged it in and it is working like new. Cost me $6 for the parts, some time and a steak dinner. well worth it!!!
Posted on Sep 24, 2010
What kind of capacitors are we talking about, so I can get them before tearing my ste up?
Posted on Mar 20, 2009
    Master:
  • 505 Answers
Check the primary caps. I had secondary cap failures like what you are describing but eventually my primary caps went as well. They get hot and are rated for a limited number of hours before they fail too. Its all about heat making the set components wear out faster once the warranty time is exceeded (this is a science not conspiracy theory). Caps are usually poor quality to begin with and need better and more expensive components to get longer life.
Posted on Jan 02, 2015
    New Friend:
Where do you get the stupid capacitors?
Posted on Oct 16, 2012
    New Friend:
  • 21 Answers
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Posted on Nov 13, 2011
    New Friend:
Where can i get these capacitors ,same or better qulaity
Posted on Aug 27, 2010
    New Friend:
Thank God for people who share this kind of info. I just today replaced the two bulging capacitors as noted, and the TV is working again. Total cost, $2.72 for the two capacitors and about one hour of my labor. The estimated repair from a shop was $300 to $600. This was for a Phillips 50 inch plasma, only 4 years old. I WILL NEVER BUY ANOTHER PHILLIPS, however I will keep this one going for as long as possible (considering the price Ipaid). Can't thank you enough moldymac!
Posted on May 13, 2010
  • rogercrash Aug 27, 2010
    can anyone tell me where to buy these capacitors, lke fo like or better replacement quality,, thanks
    New Friend:
I replaced the 2 capacitors, turned it back on there's sound and no picture, in 15 seconds red blinking lights flash 7x again and again after another.
Posted on Feb 27, 2010
    New Friend:
  • 4 Answers
Thanks to all. This worked great. Opened it up and the two capacitors were bulging. Replaced them myself and now we are back in business.
Posted on Dec 31, 2009
  • zuev-tv Oct 06, 2010
    In addition to the aforesaid I shall note:
    To prevent failure of these condensers them it is necessary to shunt
    Tantalic condensers or (as the version) ceramic - then will not be relapse.
    New Friend:
Same tv. same problem. same two capacitors. Took the board to a computer shop had them order the capacitors and replace them for forty dollars. Problem fixed. Just cracked a beer and am watching the tv to celebrate.
Posted on Jan 22, 2011
    New Friend:
This fix it worked for me. I had the exact same problem. The explanation and the instructions above were a huge help. I took the circuit board out and called around to different repair shops. I am in New Jersey and the best price I found was $95 for parts and service. I put the board back in and the TV worked. I greatly appreciate the guidance. Thanks
Posted on Jul 15, 2010
    New Friend:
Philips flat screen red flashing , seven times i unplug and plug it back again a few times it will turn on
Posted on Apr 20, 2010
    New Friend:
Always test your outlet first. HDTVs are sensitive at the ground prong. Also, purchase an upscale surge protector. FIXED MINE!
Posted on Apr 15, 2010
    New Friend:
Tailsfurse, thank you!!!!!!! The quick fix seemed to do the trick so far all tho it may not do it for long, moldymac suggestion will be next. I agree that there should be some kind of recall. I just cant justify spending 1500 for a tv and within 2-3 years having to shell out another 300-500 to fix it. What ever happened to quality made? Thank you again Tailsfurse....
Posted on Nov 26, 2009
I HAD the power supply replaced.... that was it. $270. The end. :)
  • tommyr1962 Jul 07, 2010
    What kind of power supply was it?
6ya staff
SOURCE:
I have phillips 42pf9631d/37 that wont turn on and blinks red seven times
JUST A SUGGESTION..
Oct 25, 2011 | Philips 42PF9631D 42 in. Plasma Television
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
My plasma philips tv dosent turn on and red light blinks 6 times
Power supply board have dead capacitors.U know how to solder?Replaced these capacitors that bulge up,puff up or burst open.Should get ur power back.Or replaced a whole power refurbish power supply buy it at Shopjimmy.com,Ebay.com.
Feb 06, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
Flashing red power light
probably some capacitors need to be replaced. i just replaced to in mine today and the tv works great.
Jan 25, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television TV wont turn on..I get the initial green power light, but it quickly goes to a flashing red light (flashes a series of 4 times). Philips tech support is a joke....
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Jan 08, 2010 | Philips 42PF9631D 42 in. Plasma Television
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Check the power board for caps with the tops bulged up. 3300uf 10v.
May 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
TV will not turn on, the light goes from green to red.
I own the same model. You have 1-2 Blown Capacitors. Take off the back cover, And look towards the center of the main power board. Look towards the center of this, and there are 2 capacitors side by side. You should see them swollen at the tops, even maybe a little black residue that has come out. I soldered on 2 new ones, and bingo! I would suggest replacing them both.
Dec 13, 2008 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television Logo
36,068 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
