SOURCE: getting 60 minutes back on my flip video ultra
Help, on Flip.com also has procedures for getting all your minutes back
SOURCE: Hi I have a Flip
1) Put your Flip Ultra back into the pakaging box
2) Keep it safely inside your fridge (make sure the fridge isnt on or the best is an old fridge model)
3) Scratch your head and scratch your nuts in the same time for thirty second
4) Turn on your Flip camera, press the red button for setting, and change it to indonesian language. If no indonesian language in the setting, shake it 3 times. It surely has.
5) Jumping around on your parent bed.
6) Sing Britney Spears song and film it yourself.
7) Press stop button
8) Post it on youtube.
I hope this will fix ya problem. Have a nice day :)
SOURCE: I just bought my 11
You need to first Charge your camcorder battery pack.(mine had to charge over night) the first time. Plug the little arm that extends from the camera into a USB 2 port on your computer and make sure your computer stays ON during the charging, otherwise the camcorder will not charge. A red light will come on during charge and goes off when charged. If it does not come while plugged in try a different USB port. Screen should light up temporarily and Red light showing charging on front of camcorder. IF YOU HAVE ALREADY DONE THE ABOVE, and are having the problem, pull the battery pack out and reseat it back in there again. maybe connection not good. OH, and I think mine had plastic covering the metal connections you may want to check that too -remove if so----- BUT the entire white plastic around the batteries STAYS IN PLACE do not remove that. If that still doesn't work I would try regular AA batteries in it if in fact you have The FLIP ULTRA HD it will take regular batteries too. IF they work - then maybe you got a defective Rechargeable Battery pack and should contact Flip Video at http://www.theflip.com/en-us/
SOURCE: lost time on flip ultra video camera,was 2 hr, now
The Flip has a hidden file folder where it stores files that might not have been properly removed. To clear these off the Flip. Use the control panel on your PC to allow access to hidden folders and hidden files. Once this is enabled, search the Flip for a folder called "trashes". Emptying this folder will clear the memory and return the Flip to it's full time.
