Question about Symantec Norton AntiVirus 2004 - (Open Box) for PC
When i used norton ghost it will not proceed to copy disk to disk?
Norton ghost2003
  • Tim Babcock
    Tim Babcock May 11, 2010
    Whats the question?
    Scholar:
  • 181 Answers
Now the symantec is not supporting this version of the norton ghost,you have to get the upgraded version of the norton ghost 14.0
Posted on May 04, 2009
6ya staff
SOURCE:
How to use norton ghost
GHOST is a program to copy one ENTIRE disk-drive to another disk-drive. Check www.norton.com for details on how to use the software.
Feb 26, 2014 | Microsoft Windows 7 Home Premium 64BIT...
IM USING GHOST TO TAKE IMAGE FROM ONE HARD DISK TO ANOTHER.IS IT POSSIBLE TO TAKE IMAGE FROM ONE HARD DISK TO TWO ANOTHER HARD DISK AT A TIME.IS IT ANY S/W TO DO THAT.ARE ANY SOME OTHER WAY
If the hard disks are identical and they are connected to identical computers, you can use UDP cast. This can be downloaded from the Internet, free of charge.
The computers should be on a network for this.
Copy UDP Cast to CD and boot all the computers with the CD. Select the source computer as the 'Sender' and other computers as 'Receivers'.
Start to send from the source computer. Probably In an hour, all computers will have a 'ghost copy' of the source computer.
Using this method you can 'ghost' even 20 computers!
Nov 12, 2010 | Symantec Norton Ghost 14.0: Windows
Ghost disc will not boot, not recognized as valid windows copy
If it's a Norton disk, call Norton, it should be bootable. If it's a disk you burned, it may not be a bootable system disk. Make sure your computer is set to boot from CD/DVD drive in the bios (setup) Press F2(usually, sometimes it's delete) while booting, go into setup, and make sure under boot devices/sequence that your disk drive is first in the boot sequence. Try the disk on another machine to see if it's the disk, or the machine. If it's the disk, Call Norton (if it's theirs) or have someone make another one for you.
Jun 12, 2010 | Symantec Norton Ghost 14.0: Windows
Error Copying old c: drive w/Ghost 9
Do a disk defrag on the source drive. If that doesn't work, you may have a virus on your source drive and norton ghost is catching before getting on your destination drive.
Nov 24, 2009 | Symantec Norton Ghost 9.0 for PC
As I try to convert my IOMEGA hard drive from FAT32 to NTFS, using Windows XP's CONVERT command, it discovers a drty bit on the drive. However, when I test it with CHKDSK, Windows finds no problems at...
Does anyone you know have a copy of any sort of disk management tool such as acronis disk director or norton ghost?
If yes, you can copy all the info that you still want to keep with the disk management software, and then do a total wipe and format.
MS convert will not do a complete job under normal circumstances (at least in my experience), so you are better off using a third party software suite.
Apr 17, 2009 | Computers & Internet
One key recovery is deleted
if you mean to restore the one key recovery
copy the one key recovery partition from other laptop with Hiren all in one Cd
http://www.hiren.info/pages/bootcd
inside the cd you can found norton ghost
run it
then choose the operation
choose partition
choose to image
save to any partition
then proceed the image creation
then copy the file *.gho
to your hard disk drive
then make a partition that at same size with the one click recovery partition
then run again norton ghost at hiren CD like before
choose partition
choose from image
designate where the .gho file is located
then follow the prompt
------done------
Jan 24, 2009 | Lenovo 3000 Y410 Laptop
Disk copy
yup... norton ghost should be able to copy the failing disk onto a new disk, Disk -> disk copy
Sep 28, 2007 | Dell PowerEdge 1650 Server
Reinstall Os
I'm not entirely familliar with this system and also it appears to be discontinued from the manufacturer, http://www.mfdigital.com/ it may be possible to "clone" a disk from a working one using Norton ghost or something similar. (but that means finding someone willing to let you dissasemble their working one), with norton ghost you should be able to copy entire disk from the working disk to a new disk. the manufacturer does have a firmware update disk for this but that most likely only updates the system once it is working. Gareth
May 29, 2007 | MediaFORM CD 3702 Burner
Symantec Norton AntiVirus 2004 - (Open Box) for PC Logo
65 people viewed this question
Top Symantec Computers & Internet Experts
Ekse
Lisa
Lisa
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
