Lack of hammering action usually indicates a lack of lubrication or worn piston orings. This hammer as well as many other makita hammers work with a piston moving forward and back within a cylinder. This piston moves a second piston within the cylinder with a pocket of air (pressure and vacuum). If there is a lack of lubrication or orings are worn, you will not get a good hammering action /force out of the second piston. Time for good cleaning and apply factory lube. Parts are at www.toolpartsdirect.com Good luck
