Question about Toshiba 37AV502U 37 in. LCD HDTV
It seems like the volume down button is stuck. As soon as you power on the set it turns the volume down all on its own. I've check the button itself and removed the batteries from the remote. Don't know what to try next.
  • Toshiba Master
  • 5,138 Answers
Try some contact clean on the Vol- and Vol down contact switches,either the Vol- contact is dirty or it needs to be replaced. Mats Electronics has contact switches 1-800-628-1118
You could have a problem with Poor Solder Connections on Boards.
Posted on Apr 12, 2011
6ya staff
SOURCE:
After a power surge TV controls will not work have to hold the volume button to turn up the volume
Stephanie, TV will have to come apart to check for bad capacitors,etc. on the internal board.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Toshiba Televison & Video
32'' insignia TV volume stuck down
This may turn out to be a failed component internally.
Dec 31, 2013 | Insignia Televison & Video
When I put batteries back in remote control it automatically turns volume down, when I take batteries out everything seems to work OK manually
It seems like the volume button is stuck on the remote itself. If you can, try and clean the remote and see if you can free that button.
Jan 07, 2011 | Sony STR-DA90ESG
Volume turns down by itself
Its the buttons on the tv, they need to be replaced, or replace the whole key pad on the tv. that should fix ur problem
Mar 17, 2009 | RCA F36650 36" TV
Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
First try turning the TV on from the Power button the set itself (assuming it has one).
If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
Apr 07, 2008 | Televison & Video
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
** sound
Hide the remote from the set for awhile and see if some sanity returns. If that's the case, service or replace the remote. (Check the batteries first...accordianman
Mar 09, 2008 | Sony DAV-SB100 System
Older GE television sound trouble
The first thing to check is the push button assembly maybe the volume down button has been pushed in too hard/far and is always making contact,sometimes when we clean the face of the tube water drips down in thru the edge of the frame in the buttonts,corrosion sets in and creates a short,if you are familiar with tv service you can chech the buttons thru the inside to make sure they are not pushed in but if you are not famliar be safe and call for assistance froma servicer.
Oct 11, 2006 | GE 32GT740 32" TV
Volume goes up on its own and stays up.
Aren you sure that the volume up button is not stuck in . It should feel just like the rest of them A little click? It could still be shorted,or the capacitor across the switch could be defective. If all this seems good then the eeprom, or the microprocessor,or the line or trace going to the volum button could be shorted. This is not a repair you should attempt unless your a tech. Now the button thong can be looked at after the set is unpluged and the back is off, gently slide out the chassis toward the rear of the set just a little and slide it back to see if the button is released. if that dosent help then you will need to take the set to The repair center. Good Luck
Jun 10, 2006 | RCA F31672ET TV
Toshiba 37AV502U 37 in. LCD HDTV Logo
179 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
