Please tell me your closest technitian in Norcross; Georgia 30093 My Chain Saw is not turning on
i cant tell you were to look but i can tell you what to look at on the saw to try to fix it,,,,first change the spark plug and check for a spark by holding the plug on the cylinder head and cranking the motor over,,,hold it down tight or it will bite you?
then check you have a clean carb and that the fule pump rubber is good,,its under the cover were the fule pipe fit on the carb clean the carb out as well,,clean the air filter out,, then give it a go starting her up,,if she runs but keeps stoping get a small screw driver and find the two small screws on the side of the cover,, one is for slow running,,one it for top reves,,,undo the slow running screw till the saw ticks over without stoping,,then hold the triger full open and addjust the full throtol screw till it wont rev any higher,,,dont have the chain brake on at all so watch your self,,,,,cutting a leg off hurts im told????
