Hello try the instructions below, if you do not have gmail or yahoo then you need to find the server info of your email provider or post the name of your email service provider so i can look up their info.
Gmail Account/Server Info
For Gmail, the configuration is
SMTP server: smtp.gmail.com
SMTP port: 587
Secure Connection: TLS
Incoming server type: IMAP4
IMAP4 Server: imap.gmail.com
IMAP4 Port: 993
Secure Connection: SSL
In your Gmail account, go to
Settings > Forwarding and POP/IMAP > IMAP Access > Enable IMAP
Yahoo Account/Server Info
For Yahoo,
Incoming (pop3)
pop.mail.yahoo.co.XX
Port: 995
Use SSL
Outgoing(SMTP)
smtp.mail.yahoo.co.XX
Use SSL
Port 465
Yahoo IMAP settings:
Server: imap-ssl.mail.yahoo.com
Port: 993
1. Delete the previously not working Gmail account in your phone
2. Press Menu
3. Select My Accounts
4. Choose the proper type of email account: Do NOT select "Google", but Exchange ActiveSync!
5. On the next screen fill out the Email address:
do not write [email protected], instead use [email protected]!
6. The username will be typed in automatically
7. Type in the password
8. Press Next
9. Press OK for the activation
10. On the next screen type in the server URL: m.google.com
11. Set Use SSL to ON (button turns green)
12. Press Set (left below)
13.
On the next screen set the options you need: Email sync, Calendar sync,
Contact sync, Task sync (below is another option in case of conflicts
between data on the phone and the server)
14. There are further more options if you press the gear icon (sync: push/manual, push days/hours)
15. Press Done (left below)
16. Wait and see: voil?, push work like charm.
Testimonial: "thanks alot..i hope it works :)...please tell me settings about hotmail as well"
thnx for it....i am gonna try it....but can you give me settings for hotmail?
hi this seems to be the most up to date info about hotmail.
- POP:
POP Server: pop3.live.com
POP Port: 995
POP Security: Enabled, SSL, TLS (Any of these options work)
- SMTP:
SMTP Server: smtp.live.com
SMTP Port: 25, 587
SMTP Authentication: Yes, Use POP/IMAP
SMTP Security: Enabled, SSL, TLS (Any of these options work)
- Exchange:
Exchange Server: m.hotmail.com
Exchange Domain: Leave Blank
Exchange Security: Enabled, SSL, TLS (Any of these options work)
hotmail info is in the post above.
Standard instructions for email inbox setup:
i have finished my corby pro email settings & i can send and recieve emails. the problem with only recieving & not able to send is the confusion between port numbers. in secure connection box three options available ' off ', ' SSL ', ' TLS '. use only SSL or TLS because the port numbers for SSL & TLS differs. just try this & you will be able to send and recieve emails.
SMTP port - 465
POP3 port - 995
Enable POP in Gmail. Don't forget to click Save Changes when you're done.Configure your client to match the settings below:Incoming Mail (POP3) Server - requires SSL:pop.gmail.comUnless you're using recent mode to download mail to multiple clients, make sure you've opted not to leave messages on the server. Your Gmail settings determine whether or not messages stay on the server, so this setting in your client won't affect how Gmail handles your mail.
Please note that if your client does not support SMTP authentication, you won't be able to send mail through your client using your Gmail address.
Also, if you're having trouble sending mail but you've confirmed that encyrption is active for SMTP in your mail client, try to configure your SMTP server on a different port: 465 or 587.
You're now ready to use POP with your Gmail address.601 views
