Question about Sharp R-520KS Microwave Oven
Everything works. Time, fan, turntable, light. It
Everything works. Time, fan, turntable, light. It just will not heat.
    Novelist:
  • 130 Answers
Magnetron and accompanying high voltage diode are usually to blame. Everything else works but the magnetron isn't resonating (providing the proper energy to excite your water molecules).
An appliance repairman can change it for you (typically $180) or you can get a new microwave.
Posted on Apr 12, 2011
Anonymous
SOURCE:
Check this one out! My GE Profile microwave heats up but I don't hear the fan. However, the inside light and the turntable stopped working at the same time. Everything else seems to be working fine. What's...
hello,
this is a maize problem that wiring (wire) this means that your oven fan has been disconnected from it position
what you need to fix up your fan back is that you unscrew your oven trace the maize that supply A/C to the microwave
this maize is connected to different object but what by you are real after is your fan and the heater including the turntable .
trace the wire down to the fan to locate the loss wire from it position and do the fixing your self because it is same maize thaat link up both together i.e fan and turning table
please note before you can do this make sure that any form of power supply is put off.
Good luck and thank for using fixya.
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Not Heating. Fan, turntable, light working.
I would definitely suspect the door locking mechanism in this case. If it was the sensor it would start and then stop within a short time.
The starter switch should click if you have the door open and time it for 01.seconds and press start. So that is the secon component to think of.
Nov 26, 2009 | Sharp R-930AK Convection/Microwave Oven
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Mar 27, 2009 | Panasonic Microwave Ovens
Over the range Frigidaire Microwave not heating. Model FMT148
This is a sure sign that the MAGNATRON needs replaced (this is what heats up the food) if every thing else works but food not cooking! 99% of time it is the magnatron!
Please rate answer!
THANK YOU!
Jan 12, 2009 | Microwave Ovens
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Sharp R-520KS Microwave Oven Logo
201 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ekse
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
