Confirm the features of your SD Card with this Nikon information...
** While "WA" (Write Accelerated) cards may be approved for use in this camera, no speed improvements will be noted over non-WA cards.
Additionally, look inside the C.F. card slot. I would bet that you will see a couple
of bent pins, one on each end of the connector. If you do find bent
pins you can usually straighten them out with a very small screwdriver. Check that the card in the slot is positioned correctly.
Keep us updated.
I straightened a pin and it now works
