Dryers Logo
Posted on Apr 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When in auto dry mode, the heat comes on for an initial warming but then does not come on and the dial does not advance. When using timed drying, the dial DOES count down but heat does not come back on after initial warming. Thanks.
James Cole
Level 2:
New Friend:
  • Expert 59 Answers
  • Posted on Apr 12, 2011
James Cole
Expert
Level 2:
New Friend:
Answers
59
Questions
Helped
7341
Points
140
It sounds like you have a faulty timer. To test it, remove timer knob and remove screws. Remove screws from behind control panel. Disconnect leads from timer motor, use a Volt/ohm meter and probe leads, if reading is high or infinity, it's faulty. Should range between 2 or 3k. You can also test the temperature selector switch. It's located next to start switch. Take off leads, probe with meter, Turn switch, reading should range from zero to infinity or vice versa.
2answers
1helpful
Dryer Timer doesn't move in Easy Care Mode
do you have heat?does it stay hot while in coll down?if so your heating element is grounded,open the door,look up and remove the two screws holding the top panel in place,pick top panel up just a little and move it to the left that should remove the top panel, put it on cool down or no heat and run it,if the heat stays on this is your problem the element is sagging and touching the metal cover around the element,the way the timer works is on timed dry it counts down like a clock until it turns off when on more or less or auto same thing the dryer starts,the heat comes on and when it hits temp. the heat shuts off when the heat is off the timer will advance to off when the heat starts again the timer stops,if the element isn't grounded then you still could have a bad element there are two elements in your dryer if one is broke the timer won't advance or some have only one element so if the timer doesn't advance you probably have no heat or a bad cycling thermostat or a bad sensor up front where the lint filter is.you'll have to check them with a meter.first thing to check is the heater located behind the drum.
Jan 15, 2018 • GE Dryers
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 • Dryers
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 02, 2013 • Dryers
1helpful
2answers
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
1helpful
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
The drum on my dryer will turn when I set the timer to any setting, but the timer does not work, nor does it heat up. Any suggestions?
See if the timer advances in the timed dry or the auto dry cycles. If the timer advances in timed dry but not in auto dry, then you could have a wire connection failure in the orange wire from the heating element to the timer.
If the timer will not advance in either type of cycle, then I recommend checking the timer part number that you are using.
2answers
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 • Dryers
3helpful
Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
Top Dryers Experts
john h
