I have a Maytag Neptune front load washer, model# MAH8700. Inside the drain assembly is a white impeller and a metal shaft that spins it. The impeller fell off and I kept getting the ND error code. What can I use to reattach that impeller? It won't stay on by itself. Thanks!
Oh forgot to add... the shaft turns without any problems.
http://homeguides.sfgate.com/maytag-neptune-washer-model-mah8700-troubleshooting-codes-102595.html. Here's the site for Maytag Neptune Washers. You can also find other modes there. Hope this helps. Enjoy.
ND== No Drain. You likely need the drain pump cleaned. Unplug and pull the washer out.
Remove cover in back. The pump is attached to the washer's floor. Pinch
off the hose from tub to pump. There's going to be some water left in
the pump and drain hose, so get a large towel ready. Remove screws
attaching black piece (motor) to white piece (housing), pull out motor
and clean the housing and motor impeller. Wear gloves, as it's always a
nasty stuff what comes out. ;) Reverse steps to assemble the pump
back together. If you don't hear pump running after completing all the
cleaning, you may need to check the wiring and/or replace main control
board located inside the console. If the pump seems to be running but no
water is being drained - replace pump. for Maytag MAH5500B the part
number is 25001052.
and clean the housing and motor impeller. Wear gloves, as it's always a nasty stuff what comes out. ;) Reverse steps to assemble the pump
number is 25001052.
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
