This codes works most of NOKIA series.
Nokia code Code function
*3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your
Nokia cell phone uses the best sound quality but talk time is reduced
my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
*#4720# With this Nokia code you can deactivate the Half Rate Codec
*#0000# Displays your phones software version, 1st Line : Software
Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
*#9999# Phones software version if *#0000# does not work
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
#pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
*#147# This lets you know who called you last (Only vodofone)
*#1471# Last call (Only vodofone)
*#21# This phone code allows you to check the number that "All Calls" are diverted to
*#2640# Displays phone security code in use
*#30# Lets you see the private number
*#43# Allows you to check the "Call Waiting" status of your cell phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
*#67# Allows you to check the number that "On Busy Calls" are diverted to
*#67705646# Phone code that removes operator logo on 3310 & 3330
*#73# Reset phone timers and game scores
*#746025625# Displays the SIM Clock status, if your phone supports this
power saving feature "SIM Clock Stop Allowed", it means you will get
the best standby time possible
*#7760# Manufactures code
*#7780# Restore factory settings
*#8110# Software version for the nokia 8110
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date,
4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To
exit this mode you need to switch your phone off then on again
*#94870345123456789# Deactivate the PWM-Mem
**21*number# Turn on "All Calls" diverting to the phone number entered
**61*number# Turn on "No Reply" diverting to the phone number entered
**67*number# Turn on "On Busy" diverting to the phone number entered
12345 This is the default security code
press and hold # Lets you switch between lines
Cheerup and Be Happy always.
FExplorer software
As I said, we need to download Fexplorer software for this mobile hack. After installation, Browse to c:\system folder in your mobile phone. Here you would find a file mmcstore. This file is actually used to store memory card passwords in a mobile phone. Rename this file to mmcstore.txt and open with notepad. Now you will see the memory card password as
it is, exactly. Mobile manufactures are now aware of this trick, and
nowadays they use better encryption methods to block access to
passwords.
Method 2: Unlock or reset memory card password of Nokia phones:
The first hack to recover the password of memory cards will not work on Nokia Nseries and Nokia Eseries
devices. Here we will use the remote lock feature for re-setting the
password. For this, go to your phones settings >Security >Phone
and SIM> and then allow Remote lock. The password of your remote lock
will be the password of your memory card. So if you want to change the memory card password, just send an SMS containing your remote lock message.
