Fault one: Power supply not supplying the 24v needed for the backlight inverter. Replace the capacitors in-line to the 24v line. Replace capacitors with same uF and higher Voltage rating. EX: 1000uF 10v --> 1000uF 35v.
Fault two: Backlight inverter has blown surface mount fuse nearest the 24v input of the backlight inverter. If not the fuse, then backlight assembly will need changed based of serial # of the board.
Thank you, hope this helps!
Please rate!
check the surface mount fuses located on the input of the 24v to the backlight inverter
also, do you have 24v coming out of the power supply going to the backlight inverter?
You have to options for this issue:
One: you could be missing an important fuse on backlight inverter. When the tv is responsive but no image is shown this is directly tied to the backlight inverter.
Two: A CCFL bulb in series has failed (internal on panel). If one bulb is going out, the tv will light for short periods of time and then the bulb fails and turns off the series, hence no illumination.
You can try a backlight inverter replacement (much easier), and if it doesn't fix the problem you can send it back to the place of purchase. If it indeed doesn't work, you know that a CCFL bulb is faulty and you will need to take apart the panel to view these (much more difficult).
If you HAVE to go the CCFL direction, you will need to expose the CCFL bulbs, power up the tv, and view it until it goes out (you will see the faulty bulb go out a second before the rest of the series).
Try these, if you have 24.5v from the P/S then your problem is from one of the two above options above.
hi,
tv model is 32lg7000-za.
power supply board looks very clean and ther is no sign of capcitors puping out
hi, power supply board has alrady got the 1000uf 35v capacitors, they are ok,
24.5v is present
fuse ok.
if tv is left unplug for 1 or 2 days you can turn it on again and use it, this morning i came and could turn it on but when i unpluged it and pluged it in again it wouldnt come on.
SYMPTOM: RED LIGHT ON THE FRONT PANNEL CAN BE CHANCHED TO BLUE AND WHEN ANY BUTTON ON THE REMOTE IS PRESSED THE BLUE LIGHT RESPONDS BUT THE SCREEN IS BLANK, PLEASE ADVISE
hi, power supply board has alrady got the 1000uf 35v capacitors, they are ok, 24.5v is present fuse ok. if tv is left unplug for 1 or 2 days you can turn it on again and use it, this morning i came and could turn it on but when i unpluged it and pluged it in again it wouldnt come on. SYMPTOM: RED LIGHT ON THE FRONT PANNEL CAN BE CHANCHED TO BLUE AND WHEN ANY BUTTON ON THE REMOTE IS PRESSED THE BLUE LIGHT RESPONDS BUT THE SCREEN IS BLANK, PLEASE ADVISE
