Yes the gears have been damaged and needs to be replaced.
Testimonial: "Very accurate"
Hi, I checked the gears and there are effectively 2-3 teeths missing. I have already purchased replacement gears, but the old ones seem to be covered with some grease. Do you know what kind of grease is recommended ?
Normal white grease for gears or some vaseline ? Anything else ?
I would use gear grease instead, or you might get lithium grease, anything that would not break down with heat or damage the plastic.
I have a Franklin chef knockoff of the saeco Vienna.
I have the same issue, but I haven't greased the unit in a while and if I open the door (the door switch is stuck) and press the compactor a little further up, the machine starts to brew. It doesn't feel like it moves at all but somehow that little bit of a push gets it going.
i will open it up and check if the gears are broken in the gearbox
Is a gearbox with two gears that are broken and need to be changed. is gear that engageserogator group. service contact.
