SOURCE: PT-47WX49E - Looking for a schematic
passer byer im in need of the schematics as well if anybody can help! email me @ [email protected]
SOURCE: Panasonic PT-53TW53G
Mikey,
There are any number of possible failures that can cause the symptoms you're describing. For example, C509 a .47uf/250v mylar cap has been known to fail in those units causing the wavy lines. On the other hand convergence amp failures can do the same thing. That unit uses two STK392-110 Sanyo amps at pos# Ic7001,Ic7002 Panasonic p/n# C5aa00000203 and more in that circuit needs to be tested and signal traced to isolate all of the problem if the amps are the culprit. In short, I don't think this is one you want to tackle with less than a 20 mhz scope and some serious background in electronics.
Bill
SOURCE: panasoic PT-47WX49E
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Can someone help me take the board out? I dont know how to take off the white clips tracers on the side??
SOURCE: Service manual for PT-47WX49E
i need the service manual as well, if possible (i'm just having a red horizontal convergence issue).
also, any advice on what to do would be swell!
my email is v6vywa002 [at] sneakemail [dot] com
thanks!!
