Tip & How-To about Computers & Internet
Windows XP, the most popular versions of
Windows, was widely installed by PC users. Do you remember after you
installing your first copy of Windows XP, how long did it require you
to realize that you didn't know the administrator password? I vaguely
remembered that it was about a week before I needed to make some
changes in the file system. It suddenly came to me to be logged on as an
administrator, but I do not know the password of the administrator!
Luckily, Windows XP (both Home and Professional versions)
have a "hidden" administrator account which is autogenerate when
install. This account usually doesn't show up on the logon screen and
most people are totally unaware of its existence. Usually it is ok
because we didn't need to user this account very often, only when we
don't know the administrator password, need access to the Windows XP
recovery console or boot into Windows XP safe mode, the default Windows XP administrator password would come in handy.
What is the Default Administrator Password in Windows XP?
Knowing the default password of Windows XP administrator account would be very useful.
The default Windows XP Administrator password is defined to blank during the initial Windows XP installation process.
I Forgot my Windows XP Administrator Password!
Windows XP User Accounts applet in the Control Panel
functions is to create a password reset disk wizard. Using this wizard,
a floppy disk or USB flash drive can be used to create a specific
password reset disk for specific user account on a specific Windows XP
computer. The password reset disk can only be used with the computer it
was created on and it can also be reused to reset the account's
password multiple times. However, you need to know the password of the
account you want to create the reset disk for, and you must create the
reset disk before you forget the administrator password
Here is how to reset XP administrator password with the XP password reset disk:
I Didn't Create a Password Reset Disk!
OK, if you forgot Windows XP administrator password
and don't have a password rest disk, you won't be able to create a
password reset disk anymore. Instead, there are several things you can
try to get access to your windows. SmartKey Windows Password Recovery
is your ticket. This password recovery tool not only works on Windows
XP, but also on all releases of Windows NT/2000/Vista/ 7 and Windows
Server 2003/2008. It works by booting from a CD/DVD or USB flash drive
and reset the forgotten Windows XP administrator password.
NOTE: If you change the administrator
password on a Windows XP or Windows Vista system with the Encrypted
File System (EFS), all of the encrypted files will become inaccessible.
The password for the Administrator account is used to create the EFS
encryption key. Changing the Administrator account back to using the
original password should restore access to the encrypted files, but I
have never tried it.
If you only need to blank the Windows XP Administrator password, here are the basic steps:
Having the capability to reset forgotten XP administrator passwords
and regain access to a locked computer can be a great time saver, but
should only be tried by an IT professional. you may probably make
things worse rather than better if you use sophisticated system or
manipulation tools
Article Source:http://recoverlostpassword.com/article/windows-xp-administrator-password.html
