Hello DJB,
Formatting the memory card is a easy process. You can format the memory card from the format option available in memory card option itself. You can also format the memory card using the desktop pc or laptop. Remove the memory card from the phone and connect the memory card in computer using the external memory card reader and format the memory card.
It is easy to format memory card manually. Just insert the card in memory card reader and connect with PC using USB. Select the memory card and right click on that. Choose Format option. This will format your MMC memory card easily. Due to corruption in memory card saved files are lost. To recover lost photos you can use Mac Photo Recovery tool.
You can simply format it by formatting software
SOURCE: MMC memory card is corrupted (1GB). does not format.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
SOURCE: my MMC mobile card got corrupted.. i hav
no solution. Get a new card. U can check the old card on laptp. If it is working then there is some fault in ur mobil
