Sometimes the batteries for these camcorders just go bad. There's nothing you can do to fix the battery itself, but you can find them really cheap online. If you don't think the battery is bad, and you just don't know how to charge the battery, you can find the manual on Panasonic's site. You can click support, and there will be a place to enter the model number. It will be on the camera, probably on the bottom. If you enter a model number that doesn't fetch results, try a different number (or combination of letters and numbers) until it does find results for your camera. Most of these small cameras have a small door, or attached cap that you have to pop up and open with your fingernail (they are small, so look carefully, most likely around the bottom or back of the camera). Plug the charger in and wait to see if the battery charges. If it does, the Palmcorder will stop turning off a few seconds after you turn it on.
