Re: I have a functional problem within machine aficio...
Look my friend this dispute belong to laser unit sychro1 not detected laser beam ***** didn't reach to drum in same time make laser adjustment 2109 an 400 dpi and 600 dpi an close machine and opened
SC322 - 1st laser synchronization error - • The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Poss causes:
Poor cable connection between the laser synchronization detector board and the LD unit.
Laser synchronization detector board out of position and angle of reflection not correct
Laser synchronization detector board defective
LD unit defective
If switching the machine off/on doesn't cure it you probably need a new laser unit. Has it been extra noisy before it failed? Whining/screeching/rattling?
sc322 is an error generally caused by a component in the laser unit. However, sometimes a faulty door switch can cause this error as well. The switches in question are the three micro-switches that change state when the right door is opened or closed. They are located on the front right side of the copier, above the fusing unit and behind a plastic cover. If you can remove these switches and test them individually, you can probably find the faulty switch. If not, you can replace all three as a set and hopefully the sc322 error will go away (once you reset the machine).
If replacing the switches do not fix the error, then the problem lies somewhere in the laser unit, possibly with the polygon mirror motor, but your best bet is to replace the whole laser assembly if you can.
· Laser synchronization detector board out of position · Laser synchronization detector board defective Also check if any cables are loose and also if the laser unit is dirty.-Clean it.
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective. BiCU board is defective.
Unfortunately,unit needs service. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
1st laser synchronization error. It is an expensive part to replace and in most cases its cheaper to by a used Ricoh. There are some 1035s and 2035s out there that run around $700 in American dollars. If you can find them.
It's possible there could be something going on with the power supply.
The toner spill can vacuumed as well as the optics and the rest of the machine can be cleaned simply with cleaner.
