Televison & Video Logo
Posted on Aug 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will my Elekta LCD TV work with 110 VAC?? The model is ELCD-4286FHD. The back panel states after "power supply" 220-240Vac 50/60htz. I was in the Middle East when I bought it and the saleman stated that it would work with US power (110Vac 60htz) but the placard would seem to contradict that. Is there a way to change the power requirement OR am I stuck rewiring the room for a 220V outlet??
Shane Kennedy
Level 1:
Habit-Forming:
  • Contributor 18 Answers
  • Posted on Aug 02, 2017
Shane Kennedy
Contributor
Level 1:
Habit-Forming:
Answers
18
Questions
Helped
7972
Points
63
You may be able to get a transformer that plugs directl into a 110V socket. Check the current/power requirement of the TV first though. This one is quite low power http://www.ebay.ie/itm/USA-to-UK-110V-to-230V-Step-Up-Voltage-Converter-transformer-step-up-ac-mains-/232068536781?hash=item36085cd9cd:g:qvIAAOSwFe5XyVnJ
kj henriksen
Level 2:
Sergeant:
Habit-Forming:
  • Expert 194 Answers
kj henriksen
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
194
Questions
Helped
37659
Points
504
Ebay.com has adapters for those situations.
5 Related Answers
Anonymous
  • 254 Answers
  • Posted on Nov 28, 2007
SOURCE: LCD TV WONT POWER ON
A dead condition usually indicates one of the following: Open fuse (often internal, and usually pops due to other circuit defects). Short (overload condition) in the circuitry. Failure elsewhere in the circuitry. Most modern electronics have some logic circuitry, and if there is a section of the circuit not working, the logic circuit keeps the set from coming on at all.
First, if your power cord plugs into the set, check that it is properly connected. If you can get into the internals, find the fuse, check it, replace with an exact or near exact size.
If problems are beyond the simple, technical expertise will be required to nail down and fix the problem.
Anonymous
  • 10 Answers
  • Posted on Feb 03, 2008
SOURCE: Gateway 26" LCD Power Supply
There is a silver lining....
Unless you physically see burned components on the power supply main board, it
is not fried. If you examine the board on the back side ( solder joint side) you will notice that there is a devider that is clearly marked between the Primary and secondary sides of the board. There will also be a large transformer accross this area.
All switch mode power supplies have optical couplers which cosist of a light emmiting diode usually infared and a photo transistor. These are for protecting the secondary side of the board or the expensive side. A typical switchmode power supply for an LCD tv will have at least three of these. They are roughly 1/4 inch long and 2/8 inch wide
and are black with four leads. They will be directly accross the marked portion of the board that seperates the primary or high voltage side of the board from the secondary.
These opticle couplers or switches cost an average of $ 7.00 a piece and are available
from any electronics supplier such as NTE.
I hope this helps. Remember it can all be repaired. Its a matter of if its economically
worth your time.
Anonymous
  • 8 Answers
  • Posted on Jun 30, 2008
SOURCE: Haier 37" LCD TV...need a power supply
There is a Haier Authorized Servicer in NYC who repairs the panels. Give them a call . Website is www.asnyonline.com
Anonymous
  • Posted on May 14, 2009
SOURCE: SYNTAX OLEVIA LT30 POWER SUPPLY
Yes they are bankrupt, and they did see repair services out to third party vendor- this appears to be phone support at $25 per 1/2 hour.
email response from service inquiry....
Thank you for contacting us. My name is Ravin and I understand that you have called in today for further troubleshooting but you were offered a paid service instead. Based on the information provided, I believe that the following steps should effectively resolve the issue:
I am sorry to inform you that, Syntax-Brillian, the manufacturer of the Olevia Brand, has declared chapter 11 bankruptcy and has ceased all operations. Because Syntax-Brillian is no longer in business the warranty for your product is void.
Amergence Technology, a 3rd party repair company, can offer paid repair services for your television and a paid service for further troubleshooting. Since Syntax-Brillian went out of business, Amergence is offering repair services to owners of Olevia HDTV's.
If you have any further questions or concerns, please do not hesitate to contact our Support Team at 866-965-3842 Monday through Friday between 7.00am 5.00pm PST
Sincerely,
Ravin
denlog
  • Posted on Dec 06, 2009
SOURCE: I need help with disassembly of Vizio GV42L LCD TV
remove all the screws and start at the bottom and push in the tabs, and work around the edges, being careful not to pry too hard, the cover has clips all around the tv. after the bottom is free and one of the corners the cover will kind of pop off if you use the palm of your hand and lightly tap as you apply sum upward pressure.
My Lcd Tv is Elekta lcd 32 inch model elcd-3209 it's screen automatically turn off but sound is still coming
If it is an LED tv then your problem is that one or more backlight leds are burnt and led/s should be replaced .
Elekta ELCD-3201 S dual current tv. Should power button be pressed for 220V? Or is it to be pressed for 110v?
what is the current at the plug,well,then that is the current,would you select 120 if you have 220,that is simplest question today
I have a 42" LCD Elekta TV, the TV model no. ELCD-4275MKII. Anyone help me to find a suitable remote control for this TV.
Search for it on Amazon.com.
I just ordered an Insignia remote replacement from there two days ago.
2answers
Model no elcd-2056 mkll elekta tv find code for rm-300e universal remote made in china
Any one help please. my tv remote not work. I want to a new remote
How to connect ELEKTA ELCD-3209V to PC ?
You can.. I am using the same model.. May be something wrong with your components..
Feb 03, 2013 • Cell Phones
2answers
LG LCD TV there no display on screen. Service person says it SNP(power supply) card has to be replaced as its supplying more current to PCB & cost is Rs. 6000. I would like to know whether the...
No power LED light indication to the tv screen panel at all or LED light power indication flashes?Yes,it is the power supply board have problems.Tries websites like Shopjimmy.com,Ebay.om to buy a refurbish power supply board for the replacement.Refurbish power supply board cost about usally $100-$110 plus shipping.
2answers
Find a differant web site because this one is run by a bunch of money grubbing technicians that really don't have a good solution but would love to charge you to take a look at it.
After you pay to have your tv shipped to them only to hear them say that it will be $700 to fix it or you can pay to have it shipped back still in its junk state most people probly say keep it and they then fix it for $25 and sell it to another ******!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
