I had the same problem:
Printer just clicked and panel indicated warming up. Tried all the USB stick thing and it wasn't reading it.
Search for usbprns2.exe in google, I ended up downloading it from some foreign site.
Place it on your desktop along with your firmware file xxxxx.hd
Connect the printer to your computer through the USB in the back panel.
Switch printer off wait a few secs then back on.
Press stop button - panel indicates download manager
Press stop again and "await image" appears.
On computer drag the xxxx.hd firmware file onto the usbprns2.exe.
The panel should indicate deleting addresses, then after loading addresses.
Printer reboots on its own and voila - working printer!
Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
