Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Whirlpool front load washing machine F 09 - Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
    Brigadier General:
  • 6,277 Answers
In general for Whirlpool washers 'F09' means 'overflow'. I would guess that there is a problem either with the water level sensing, with the control board which controls the operation of the water valves or one of the valves itself. Sorry but repair call required ;-0(
If this has at least clarified the situation please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 16, 2011
6ya staff
SOURCE:
Error code F 09
Go to appliance assistant.com/repair/duetwasherrepairguide-diagnostic-tests.php this website will help you troubleshoot along with showing you diagrams along with giving you all the error codes for your washer.
Oct 20, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader washer is not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have a whirlpool front load duet. Will not rinse or spin
heatman101
Sep 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 6AWM8143 Front Load not starting spin cycle
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Whirlpool AWM8143 Front Load Washer
Whirlpool duetsport front load washer
Check the following link:
http://fixitnow.com/wp/2008/09/27/whirlpool-duet-washer-with-f-21-fault-code/
Nov 08, 2008 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool Duet HT F 09 electrical problem
f09 is a overflow conditioncheck pump,drain hose not kinked,drain pump failure,pressure switch.
Oct 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
198 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
