There is probably a disconnection inside the iron that's why it won't light up. Usually, when the heating element get's defective, the won't heat.
If the iron has a three pin socket/plug, open the plug and check if the fuse is intact. If the fuse is intact, then it means you will have to disassemble the iron.
Check all the wire connection inside the iron, observe if you will find any disconnection of any kind. There are not much wire inside the iron, so I believe this shouldn't be difficult.
Have the iron checked by disassembling it.
I hope you understand the above......
Good luck.
