SOURCE: Maytag MFD2561HES
I just went through this problem after a major power outage from our December 2007 ice storm. I was able to reset the controller (computer?) to factory defaults and the water dispenser started working. I think it was just confused!
SOURCE: Maytag MFD2561HES not dispensing water or making
Hi. is your Maytag on the recall list? Do a google search. You may by one of the 1.6 million owners affected. If this solution has assisted you, please rate it. ricardok45
SOURCE: maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
SOURCE: Maytag refrigerator model #MFD2561HEW -
Hello, Thank You for using FixYa. I will be helping you today. Your water tank is frozen! Itson the back wall of the fresh food section if you look behind the drawers you will see it. Use a hair dryer and heat it untill you get water out of the dispenser. This is a common issue with this model.
Thank You and please rate my answer if it was helpful..
