SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
SOURCE: vertical lines on sony kdl-46v3000 bravia lcd tv
i have the same problem, apparently the LCD panel needs to be replaced and this will cost more than the tv is worth... Advice is to not buy a sony again, because this is a common problem and they wont extend the warranty, even if its 2 weeks after it runs out...
SOURCE: Sony KDL-32S3000 32in LCD TV.
Hi Chris,
I used to have the same issues with my 32S3000 but I've managed to fix it by factory reset.
It's described in a different post here:
http://www.fixya.com/support/t2222933-complete_factory_reset_sony_bravia_kdl
Good luck.
Rob
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
SOURCE: KDL-46XBR2 sony broke lcd screen
I had a kdl46xbr2 go out on me repair company said screen went bad and they told me warranty dept would not fix it cause the screen ran 2800. So now im in dis with them for a replacment tv and they wanna give me the xbr9 i want the xbr8. Theres a reason i spent 3500 on the xbr2 the bravia pro engine is in a nother class than the standard bravia.
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 975 posts to different brand TVs now.
