Locate the battery on your lawn mower. It will be under the seat or under the hood.
Remove the old battery by using the correct socket or wrench to remove the nuts attaching each cable to each terminal.
Examine the battery for any restraining hardware and if present, remove using a wrench or a screwdriver.
Carefully lift the old battery out of the mower. Using a wire brush and a solution of water and baking soda, clean off the cable ends.
Lower the new battery into place and attach the black cable to the
black, or negative terminal, and the red cable to the red, or positive
terminal. Reattach any restraint system.
Good luck.
This is to general to be of any use!
