Nikon Coolpix 2100 Digital Camera Logo
Posted on Aug 08, 2008
Warnin! Mode dial is not in the proper position
I keep getting this message everytime I turn the camera on. Can't find any troubleshooting answers on this subject. I tried taking out the batteries and letting it reset but it doesn't do a thing.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Sep 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3554
Points
6
I used to have the same problem. Make sure the picture of the setting you are using on the turn dial is lined up with the beige pointer on the top of the camera. When you turn the dial, you can feel it lock into position. It could be that the dial hasn't quite clicked into the right position and just needs adjusting.
Camera is mn35z. the message states mode dial indefinite and then shuts off.
It sounds like your camera, the Nikon Coolpix MN35Z, is experiencing an error with the mode dial. The "mode dial indefinite" error message indicates that the camera is unable to recognize the position of the mode dial. This can be caused by a variety of issues, such as a malfunctioning mode dial, a damaged mode dial, or a problem with the camera's internal components.
To troubleshoot this issue, you can try the following steps:
  1. Make sure the mode dial is not damaged or stuck. If the mode dial is stuck or damaged, it may not be able to move freely, causing the error message to appear.
  2. Check the camera's battery and memory card. If the battery is low or the memory card is full or damaged, the camera may not be able to operate properly.
  3. Try resetting the camera. To do this, remove the battery and memory card, wait a few minutes, and then reinsert the battery and memory card.
  4. If the problem persists, the camera may need to be repaired by a professional. It is recommended to contact the manufacturer or an authorized service center for further assistance.
Jan 06, 2023 • Cameras
2helpful
I have a Lumix DMC-LC50 When I turn it on it says: Mode dial is not in the proper position I tried everything
The mode dial is the knurled knob on the top of the camera - if you didn't already know. This same error message displayed when the knob is between selection. If you have moved the know to a valid position - where it stops in a detent, the message should clear from the display and be able to take pictures.
If moving the mode dial so that it rests in a detent and the message is still displayed, it indicates a problem with the switch inside the camera (that is operated when the mode dial is rotated). This is not a user serviceable part, and should be professionally repaired. I found United Camera to list a Mode Dial repair to be $42. there are plenty of others that can make this repair for you, too - this was simply the first I saw that had a price (I have never done business with nor am I affiliated with United Camera in any way).
I hope this is a good starting point for you & good luck. Please rate my reply - thanks.
1helpful
4answers
Lumix camera says mode dial is not in proper position
Hi and welcome to FixYa!
Please try to remove the battery and let it sit for atleast 5mins. then reconnect it again. This should reset the system and can resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
MODE DIAL IS NOT IN PROPER POSITION
Try turning the mode dial again. It may not have been turned properly.
1helpful
2answers
Mode Dial and Lens Problems! Nikon Coolpix 4600
i had the same problem try this: tap the outside of the dial lightly while turning the camera on it should basically "pop" right out!!!!!!!!;)
Problem with my camera
Sounds as though the mode dial is "freewheeling", i.e. it is turning...but is not revolving the wiper/selector below. Workshop job.
2helpful
Card Error
This is from Konicas site. don't know if this will be any help for you since you had posted a long time ago. you most like have a new camera by now. anyway. Question: When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the monitor display. Answer: Please follow the procedure below. While the message is displayed, press the center of the controller. The monitor display and data panel will turn off. Turn the Main Switch dial to OFF position and remove the CompactFlash from the camera. - When "No Card" message appears next time when the camera is activated in the recording mode, the camera and CompactFlash are OK. - When "Card Error. OK" appears again, the CompactFlash may be faulty. Use other card.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
