Hi jerryleigers,
The Drain pump is working intermittently. It is either overheating or a loose wire is present or it could even just be a faulty drain pump. I'd suggest removing it (Found attached to the lower sump hose), testing it by aplying direct power to the 2 pins (either way is fine, it works on an alternating current), run it for 5 to 10 min (turning it on and off every 30 seconds), if it is fine then it is a worst case scenario (PCB). If it is not running well, or it is not even starting - replace it, problem solved.
Hope it helps :-)
* If you found this answer helpfull, please rate with a 4 thumbs up and a testimonial please.
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed
when either the motor is not working or the control board thinks that the motor
is locked up. A Hall Effect sensor is used in these washers which monitors the
speed and direction of the motor and then forwards this information to the
control board. Hope you understand by now that this LE error is displayed when there
is an issue with the motor or when the Hall Effect sensor sends wrong signal to
the control. Conclusion is you'll have to check both motor and hall sensor and
replace the part# that is bad, usually I have seen the sensor going bad. Please
get back to me if you have any other questions.
Kevin
