Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
Hello, Your Maxent MX-42EPM20 is not a TV (Television) it is a Plasma panel. The difference being your Panel does not a TV Tuner (no Coax jack or electronics relating to a tuner) Below is the spec sheet that shows this http://reviews.cnet.com/flat-panel-tvs/maxent-mx-42epm20/4507-6482_7-32139310.html?tag=mncol;subnav
You can use a cable box or a cheap Digital TV receiver. You can buy them at walmart, You need one with A/V out puts such as Component. Here is a link to one. This will give you a tuner. http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box where can i find how to program remote that comes with time warner cable
I have the 55 inch. try using 246. That works on mine. if not try 028,164,208,066 let me know if that works for ya ric another note, are you using the flash on the back of your cable box or do you have a sensor in front of the DVR box?
what kind of connection are you useing cable, dish, attena... and how do you have it connected ... direct connect from a cable box or threw a vcr also are you running coax cable or the colored audio video cables?
Trying to program a universal remote can sometimes be a frustrating process. Successful programming of a universal remote depends on whether the universal remote manufacturer included our company’s information in the remote when it was assembled.
Then a cable company (ie., Comcast) or satellite provider (ie., Dish Network) orders their decoder box and universal remote control from a manufacturer (ie., Scientific Atlanta, Motorola, etc.), the decoder box manufacturer provides a list of all the possible remote controls this universal can duplicate. From that list the cable company or satellite selects which manufacture’s products to include on their new universal remote. Once those manufacturers names have been decided, they are placed on the universal remote and a numeric code is assigned. If they choose not to include our company on the universal remote, the universal remote may not access the Maxent screen.
If you cannot locate Maxent on the list provided to you by the universal remote provider, please try the following:
Through contact with various cable and satellite content providers we have developed a list of the most common numeric codes that are used with universal remotes.
We have identified other manufacturers of display products that have similar remote control information to ours. Depending on the universal remote you are using these manufacturers may work. Please use the documentation that accompanied your universal remote, and look up the following companies. Input the numeric code associate with that company.
Gateway Sampo Viewsonic Magnavox Phillips Marantz Pilot
If the universal remote you are trying to program contains a Code Search (the remote will scan through all the codes contained within the universal remote) function, we recommend that you try that procedure. It is possible that there may be another manufacturer code that may work with our monitor.
You may also want to try a Learning Remote from another manufacturer. This type of remote control can absorb or record the information coming directly out of the Maxent remote control. The learning remote then duplicates that information and acts like the Maxent Remote control. This type of remote can also record the signal coming from your other universal remotes in the same manner. In which case you can use this learning remote for your entire audio video system
please rate the chat session that got disconnected due to slow server if this helps.and if does not helps please reply for further help.
Use the instructions that came with the device for full details. Their site is down, so you can't get a manual online at this time.
Usually, all you need is video input (a cable connection) and power.
If you have a straight cable line (no box), coax cable connection is will work if supported.
If you have a box, the better cables support the RGB and audio split, and will give you a better quality picture.
Be sure all are secure connected, and that if you use the RGB/Audio split connection, be sure each matches the color coding on the connector.
Trying to program a universal remote can sometimes be a frustrating process. Successful programming of a universal remote depends on whether the universal remote manufacturer included our company’s information in the remote when it was assembled. Then a cable company (ie., Comcast) or satellite provider (ie., Dish Network) orders their decoder box and universal remote control from a manufacturer (ie., Scientific Atlanta, Motorola, etc.), the decoder box manufacturer provides a list of all the possible remote controls this universal can duplicate. From that list the cable company or satellite selects which manufacture’s products to include on their new universal remote. Once those manufacturers names have been decided, they are placed on the universal remote and a numeric code is assigned. If they choose not to include our company on the universal remote, the universal remote may not access the Maxent screen. If you cannot locate Maxent on the list provided to you by the universal remote provider, please try the following: Through contact with various cable and satellite content providers we have developed a list of the most common numeric codes that are used with universal remotes. Content Provider/Most commonly used code Comcast: 1755 Comcast (ML-3251HLT Model): 0054 Insight: 1755 Direct TV: 11755 Dish Network: 742 Cable Vision: 165 Adelphia: 0156, 1755 Universal: 0762 One4All: 0036 Time Warner: 0230
We have identified other manufacturers of display products that have similar remote control information to ours. Depending on the universal remote you are using these manufacturers may work. Please use the documentation that accompanied your universal remote, and look up the following companies. Input the numeric code associate with that company. Gateway Sampo Viewsonic Magnavox Phillips Marantz Pilot If the universal remote you are trying to program contains a Code Search (the remote will scan through all the codes contained within the universal remote) function, we recommend that you try that procedure. It is possible that there may be another manufacturer code that may work with our monitor. You may also want to try a Learning Remote from another manufacturer. This type of remote control can absorb or record the information coming directly out of the Maxent remote control. The learning remote then duplicates that information and acts like the Maxent Remote control. This type of remote can also record the signal coming from your other universal remotes in the same manner. In which case you can use this learning remote for your entire audio video system
