What does E3 mean on Maytag Neptune washer?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
What is E3 error on Maytag washer?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
How do I fix E3 error on my washing machine?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
What does E3 and F6 mean on Maytag washer?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
Feedback
DSLReports
Aug 5, 2007 - 19 posts - 8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
http://homeguides.sfgate.com/maytag-neptune-washer-model-mah8700-troubleshooting-codes-102595.html. Here's the site for Maytag Neptune Washers. You can also find other modes there. Hope this helps. Enjoy.
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Replace the clutch.
