I tried everything and then decided to slightly change the above instructions to: Open the front cover and WA LA it worked!!
press Clear/Back
Replace New Drum - select "Yes"
after the screen will show "accepted"
close the front cover and you are good to go
To solve the problem download the user guide from here
Drum Error:
The corona wire on the drum unit
needs to be cleaned.
Clean the corona wire on the drum unit.
(See Cleaning the corona wire on page 122.)
or
The drum unit has reached the
end of its life.
Replace the drum unit.
(See Replacing the drum unit on page 130.)
and / or
press Clear/Back
Press Start, then 00
after the screen show "accepted"
close the front cover and you are good to go.
Link to downloadable pdf.: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc7340_us_as&dlid=&flang=English&type2=-1
End of Drum Life Soon
SOURCE: drum error
With that error you need to remove the drum, run the little blue tab on top back and forth about 20 times, blow out the area below the blue tab, and re install and try printing again. If the error is drum life end you need to open the front door and press either menu or options, sometimes the clear/back button and tell it it's a new drum.
SOURCE: troubleshooting and routine maintenance chapter
goes through below link and down the user guide .....
http://welcome.solutions.brother.com/BSC/public/as/as_ot/en/model_top/colormfc/dcp165c_all.html?reg=as&c=as_ot&lang=en&prod=dcp165c_all
