The power supply of your TV must be check.the power output of the power supply suppose to be 12 volts for audio,24 volts for the backlight lamp and 5volts for the main CPU. use a multimeter to measure the voltage In the case of your TV it seems only 5 volts is present that is why you have a power indicator lit....open the back cover of your TV and measure the power supply.power supply board is where the power cord is connected...
