HP 39g Calculator Logo
Posted on Apr 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i use log functions on the HP 39g+. For instance i want to use log10 1000 which should equal 3 or 3^5=243 so log3 243 should equal 5. If i press log the calculator shows: log( If i write log(3) then add 243 to show log(3)243 the answer is 115.940 NOT 243 5 like it should be. Please help.
k24674
Level 3:
  • HP Master 8,093 Answers
  • Posted on Apr 19, 2011
k24674
HP Master
Level 3:
Answers
8093
Questions
0
Helped
4674541
Points
21596
To calculate the common log ( LOG base 10) of a positive number, just press the LOG key, the one above the blue Division key, then enter the number and close the right parenthesis. Press the ENTER key to get the result.
If you want to calculate the log in a base other than e (natural) or 10 (decimal) logarithms, you need to make use of one of the equivalent formulas below
log in base a of a number b
log_a(b)=log_10(b) / [ log_10(a)] or
log_a(b)= ln(b)/ln(a)
2logx+log3\4-log(2x+3\4)=0
easy:
2log(x) + log(3/4) - log(2x + 3/4) = 0
log(x^2) + log(3/4) = log(2x + 3/4)
log(3/4*x^2) = log(2x + 3/4)
3/4*x^2 = 2x + 3/4
multiply equation by 4:
3x^2 = 8x + 3
3x^2 - 8x - 3 = 0
solve this quadratic eq. and you get
x1 = 3
x2 = -1/3
does it make sense?
1helpful
How do I do logs with different bases (bases other than 10)
Most calculators can't do logs in different bases, but you can solve for the answer this way:
Let's say you need to take the log of 5 in base 3. This can also be written as log5 (base 10)/log3 (base 10).
A more technical solution can be found here: http://oakroadsystems.com/math/loglaws.htm#NewBase
I want to know how to enter basic logs into the calculator: Example. Log3^9=2 How can you enter this into the calculator?
The 30XA only has logarithm functions for base e and base 10. However, you can calculate the logarithm to any base by using the relationship logb x = log x / log b = ln x / ln b
To calculate log3 of 9, press
9 LOG / 3 LOG =
or
9 LN / 3 LN =
How do I figure log3 9 on my ti 30?
Calculate it as log(9)/log(3) or ln(9)/ln(3). For example, LOG 9 ) / LOG 3 ) = or LN 9 ) / LN 3 ) =
Cant find the Log function on the EL 733A
There is no common logarithm function on this calculator. However, you can calculate it easily enough using the natural logarithm function (ln). The log of x is equal to ln(x) / ln(10). In words, calculate the log of a number by calculating its ln then dividing by ln of ten.
Write the expression as a single logarithm. 2 log3 u - log3 v
log3(u^2/v)
You can move the top as an exponent because of the rules of logs. Then subtracting two same base logs can be combined because another rule. If they are subtracting you divide them and if they adding you multiply them.
1helpful
How do I transfer notes computer to a HP 39G+ calculator
The 39g uses its own format for notes. If you want to create notes on your computer, you need to use the Aplet Development Kit, available at http://www.hpcalc.org/details.php?id=5217
How do I enter an inverse log function into my claculator? for instance log-1(-.4/10)
If you want to do correct mathematics you should strive to use the right words to express the concepts, and the right symbols too. While the logarithm function has an inverse function, it is never called an inverse log and it is never represented as log^-1. (I know you are going to protest and claim that the inverse of a sine function is represented on calculators by sin^-1. This a manufacturer shortcut, and we have no power to change that.) HP uses ASIN, ACOS, ATAN. These are still manufacturer shortcuts but they induce fewer errors.
Anyway, the logarithm functions do have inverse functions.
1. Natural loogarithm (ln)
The inverse of the natural log is the exponential.
ln(e^(x))=e^(ln(x)) =x
2. Common logarithm (logarithm in base 10)
The common logarithm has an inverse function, often called the antilogarithm or antilog.
There is an equivalence.
y=log(x) <--> x=10^(y)
From what I undesrtand of your exemple, you are looking for the antilog of the number -0.4/10 (or -0.04.)
-0.04= log(x), what is x?
You use the equivalence above to look for x as follows.
x=10^(-0.04) =0.9120108394.
Use the change sign (-) not the regular MINUS sign.
Take the log of the last result (still stored in Ans memory) and you get the original number.
Hope it helps.
I NEED TO DO LOG 10 CALCULATIONS THAT I HAVE NOT DOEN FOR YEARS AND DO NOT HAVE THE INSTRUCTIONS HADY. cAN YOU HELP ME WITH DRIVING THE 20S?
Enter the (positive) number , press [Left Shift: blue][LOG] to calculate log in base 10
12 [Left Shift][LOG] gives 1.079181246.
In general Functions in blue are accessed with left shift. functions in Yellow/Orange are accessed with RIGHT SHIFT.
As to the manual, there is not any around in the Web,except the Spanish version at hp Spain. This is one instance where it pays to speak in (foreign) tongues.
If you want the link, post to this thread and I will be happy to supply it.
Hope it gets you back in gear.
I need to know how to put in the info for tan^(-1)(whatever)=
Press SHIFT [ATAN] whatever ENTER
ATAN stands for arctangent (inverse tangent, tan^(-1)) and is the shifted function of the tangent key.
k24674
Grand Canyon Tech
Grand Canyon Tech
