Try taking the battery out and putting it back in, also there should be a small reset button. You will need a toothpick to push the reset button. Allow time for the scale to reset before stepping on it.
Hi, am using a kambrook body fat scale, I have changed batteries several times but it keeps saying LO please assist me.
Thanks
SOURCE: mY bfm588dq-81 scale is malfunctioning. The
My Health O Meter BFM5955KD-60 scale is malfunctioning. The display keeps saying ''0'', when it proceeds to display my weight, then shuts off. I replaced the batteries several times, but it keeps displaying ''0'' and shutting off. This is a brand new scale.
SOURCE: My bathroom scales ww35cha stopped working, i
you have 4 button on this model
1 tap the scale to start, it show 0.0
2 tap set to set person and height, age ...( use set, up, down buttons )
done
when start use
1 tap scale to start , show 0.0 again
2 tap user again and again to choose your user
3 wait after it show your height, age, then it show 0.0 step on the scale and you're done.
i've been through becuase my friend lost his instruction manual.
Now it wook
Have Fun
[email protected]
SOURCE: Scale shows "Lo"
just fixed this problem myself. so first i took out the battery then put it back in didn't wait a specific amount of time or anything. i just popped it out blew the inside then put the battery back in. next i switched it to ST from LB stepped on it stepped off it then stepped on it again and it reset. then i put it back to LB and voila it worked again!
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
SOURCE: I have a Conair Weight watchers digital scale, how
replace it with 9v lithium battery that you can get anywhere.
http://www.google.com/products?q=+9v+lithium+battery&hl=en&aq=f
