there is dirty water still in the m/c do a boil wash with nothing in it buy some nice smelling conditiner and poor some of that in it also this is a tip from my mam leave the door open when not in use to let the insides dry out
If you dont wash whites with clorine bleach, you may want to every once in a while. Clorine kills germs and backteria which can smell. washer pumps do not get 100% of the water out.
When a moldy or musty smell develops in a washing machine, many times
the smell is coming from the open areas of the agitator. Water along
with soap and/or liquid softener sometimes splashes into an open
agitator, and when the lid is closed it does not dry out. Instead, mold
begins to form, and a musty smell wafts from inside the machine, even
after the lid has been opened for an extended period of time. Until the
mold is removed the washing machine will continue to smell bad, even if
it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect
in the holes, and when it does not dry fast enough it ends up smelling
musty and moldy. Even the top of the rim can become moldy and musty, but
proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
It sounds like a build up of washing residue. Clean inside the door seal and do a very hot wash with a bit of washing powder and no clothes. Repeat this once a week until smell has gone.
