its most likely over heated. Try removing the plug and moving it away from the tv and any heated areas for atleast a day, then try turning it on and it should work..
If it only goes into protect when you put a dvd in then change the regional code.
Hi, Try this 1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
i JUST tried the unlock to multi region for my samsung ht-tz315 and it didn't work does anyone have a crack for this please. thks
the code was
Turn On player with remote Press Enter on the remote Press 8, 4, 2, 6 and 9 on the remote Press Enter on the remote The player will power Off Switch On power from remote
DVD players come out of the factory region locked. You can either buy an player that does not have a set region (you can only get these online) or you can unlock the DVD player on a computer using software.
i want to manke my samsung Ht-tz212 region free
I have the same problem
need multi region code for Samsung HT-D450 pls
