Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
How Do I Replace Brushes on DW056 - Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
peterrance19
peterrance19
  • 399 Answers
SOURCE: DEWALT DRIVER DW056 DIAGRAM SHOWS MOTOR AS A
hi atlas cop co supply and service all dewalt they have a webb page and are based inhemel hempstead hertfordshire england they also have an help desk hope this helps
Posted on Nov 15, 2009
There is no power when clicking the trigger
try another battery. If it still doesn't work it's either the switch or the motor. You can take it apart and hook the motor directly to the battery. If it runs the switch is likely bad. If not the motor is bad. Since it doesn't have servicable brushes you replace the motor. Be careful when you take it apart because the switch is static sensitive and you could damage it! Do the work at a static sensitive station.
Dec 25, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Can you change just the bushes on a dewalt dw056
No, the brushes are part of the motor and pinion, Dewalt part number 607990-03. If you search "dewalt 607990-03" you can find several on-line vendors that sell the motor. They run about $50 plus shipping.
Jan 28, 2011 | Dewalt DW056 18 Volt Cordless Impact...
I have the dewalt dwo56 impact driver and ive had it for a yr and i have no warranty on it ..i have a problem with the drill when i press the button for it to work it doesnt you have to shake it or tap it...
That's where I would start. If your warranty is void, I would take the screws out of the body and investigate. Look at the brushes for proper wear and position, then check the connections at the switch for a loose wire or bad connection. If all looks good, check the battery connection clips at the tool. Good luck.
Dec 07, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Problem to work
Either brushes or trigger. I would check brushes first. Juraj
Jun 06, 2010 | Dewalt DW056 18 Volt Cordless Impact...
I have a DeWalt DW927 cordless drill. It's lost
the brush assembly slides out of the back of the motor. I suggest going to Dewaltservicenet.com and downloading a breakdown for this tool before starting. I don't think that the brushes are going to be your only problem though.
Dec 21, 2009 | Dewalt DW056 18 Volt Cordless Impact...
DEWALT DRIVER DW056 DIAGRAM SHOWS MOTOR AS A SEALED UNIT AND NO BRUSHES AVALIABLE SEPERATLEY IS THIS TRUE ORT CAN YOU GET THE BRUSHES
Nov 10, 2009 | Dewalt DW056K-2 18V Impact Driver
Drill Motor Reliablity
some models have external brushes for easy changing - when the brushes wear down you can easily change them for new ones, some models have this feature ,it is only of use if you are using your cordless drill on a daily basis.
Aug 27, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DWo56 18 Volt cordless impact
all drill has brushes. this particular drill you need a motor assy
or switch. vibration & heat are common problem cu'z the drill not to properly
Mar 17, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
235 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
