Canon PowerShot A470 Digital Camera Logo
Posted on Apr 21, 2011
All pictures taken outdoors and under sunlight are all white, pictures taken indoors during the day and under light at night are all right. any solutions?
  • Anonymous Jun 20, 2012
    PLS VISIT THE SERVICE CENTRE IN BANGALORE-MATA ELECTRONICS, NO 86. 1ST FLOOR, SP ROAD, OPP TO ANKIT INFOTECH. BANGALORE. CONTACT MR VIJAY 9035871324
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Apr 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
898
Points
16
Outdoor pictures are all white
Double check the mode the carera is in to make sure you are not in manual mode. Most point and shoot digital cameras have an auto mode. Try putting the camera in auto mode to see if that helps. In manual mode you have to select the appropriate Fstop setting (how much light gets through the lens) and the shutter speed (how long the lens stays open during the shot).
When pictures are taken outside during the day they are unclear with some white horizontal lines and when taken indoors its ok.tried everything the manual said but still no changes
White shadow or white lines may occur if the light was too bright when you take the picture, especially in strong sun light. Have you turn off the flash light when you taking those picture ? If you haven't, then you should try to turn off your camera flash light manually. And I must remind you not to take a picture with your lens faced the sun light or other light (lamp etc) directly. Even if you take a picture outdoors, try to make your lens shaded by something, you can even use your own shadow to shade them.
Hope this help and be kind to rate please.
(^_^)
Jan 08, 2011 • Cameras
27helpful
7answers
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear..
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
I have been using this digital camera for a while
You need to change the white balance to tungsten lighting.
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Dark pictures at times on auto is there a fix? Camera Fuji s1000
when you think that there is less light or whn you are taking a picture indoors or during night times under auto then reduce the ISO acordingly like if the lighting is of the indoor lighting then you can place the ISO at 80-200
if outdoor and during night time 80 or below and so on depending on the light conditions
the lower the light the lower the ISO
this would increase the shutter time though improving exposure quality
happy clicking
1helpful
Outside pictures turn white
Check the white balance. This should be under menu. When you are outside in sunlight, change is to the sun icon, ect.
Are the exposures very long? If they are, they need to be shorter in high light, and longer in lowlight situations.
Casio exilim EX-S500 overexpose
i have the same exact problem with mine. it's two and a half years old as well. i also noticed that if you try taking pictures in any of the best shot modes the pictures come out looking like paintings.
also, did you ever try cleaning the lens?
White lines when you take photos in light, but perfect in the dark
The problem lies in you camera's CCD unit which is located on the back of the lens held on be 3 small screws it could also be a setting in the camera's menu try going into the menu and reseting the camera to default it works some times if that does not work than you need the ccd replaced pretty easy fix I fixed 1 with the same problem about two weeks ago for someone it happens I hope this helps you out.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
