Navigate to this page -->Disassembling Olympus Stylus 1010 LCD Display
I suggest check this procedure for Olympus Stylus that has a 2.7 inch LCD screen :
1. Turn the camera off and remove the battery from the bottom the camera. If you need to replace the Olympus Stylus screen you will first want to remove the power source from the camera.
2. Remove all the small Phillips screws from the sides and bottom of the camera.
3. Pry the camera apart using a small slot screwdriver or butter knife. The camera will come apart in two sections. The front will contain all circuitry and the lens assembly.
4. Remove the screws that connect the LCD to the camera. Lift the LCD screen up and follow the ribbon cable back to its plug on the circuit board. Remove the connector plug and set the LCD aside.
5. Plug the new LCD into the plug on the circuit board. Carefully align the new screen onto the circuit board by lining up the screw holes.
6. Insert the screws and tighten them evenly so the LCD screen sits in its proper position.
7. Attach the back camera casing to the front, replace and tighten all the screws. Insert the battery, turn the camera on and your camera is ready to be used again.
Hope helps.
THE INFORMATION YOU GAVE WILL WORK ON A STYLUS 840. THE1010 IS A LITTLE DIFFERENT DOES THE KNOB ON THE BACK HAVE TO COME OFF FIRST?
