This is a Clutch issue. Google this; Neptune TL Washer FAV6800AWW This is a DIY Appliance repair forum and you can get the Service Manual and owner repair support at that site.. In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues (this issue) that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
I can
""Tumblers slowly spin around during spin cycle as tub is rotating. Sound like a Clutch problem? ""
Yes it is!
You are ready for an Outer Tub rebuild google this to see what is involved ""FAV6800A/FAV9800A Outer Tub bearing replacement""
$50 to $60 for Tub seal Tranny O-ring and bearings. I would not pay more then $80 + shipping for the Clutch Pulley if yours can't be saved. Google this p/n 25001169 and I can't offer detailed DIY repair on this forum.....no edit feature is a pain.
Why did yuou replace the tranny? ""Replaced a transmission a year ago and inlet valves as well""
10 year warranty was it a warranty repair? If so it's the 1st one I have seen in many, many post across 5 forums I help at.
Google this Neptune TL Washer FAV6800AWW 5 post down.
Here ya go.....in this post I discuss the issue related to unbalance error codes DC and UC;
Your FAV6800A or FAV9800A is going off balance with DC or UC unbalance error codes during spin cycle and you see/hear the wash tub banging around at the start of Spin Cycle of the wash cycle or a Spin Only cycle. If this is the condition the TDS (Tub Displacement Sensor) is working as designed and signaling the Control Board properly of an unbalance wash load condition.
The Control Board receives a varying D.C . Voltage from the TDS sensor and if the out of range D.C. Voltage limit continues the Control Board will halt the Spin Cycle and try to redistribute the wash load. If you are interested I will show you how to monitor the TDS input to the Control Board with a DVM.
The Control Board then starts the Spin Cycle again. If the wash tub/basket out of balance condition continues the Control Board will attempt another redistribute of the wash load. After several attempts (4 to 5 I believe) the Control Board will shut down the Spin Cycle and send a error code DC or UC to the LED display of the FAV6800A, my machine type. And I believe a text statement to the LCD screen of the FAV9800A machine i.e. something like "Unbalance Condition" I'm not sure what the text message is.
If you need help open a post in that repair forum and I will try help you through your issue.
The forum is free and my time is free I just don
Thanks. Already greased the clutch. Little rust, but working like a charm now.
Replaced tranny due to seal leak and water in tranny contributing to leak a bit ago.
Warranty? Not after one year. Rust through goes to ten. Tumblers and controls through five years. Machine is seven years old now.
