Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
What is the name of the tool to adjust the carburetor on the 125l husqvarna weedeater
  • Husqvarna Master
  • 1,807 Answers
Its a husqvarna tuning screwdriver
Posted on Aug 03, 2013
6ya staff
SOURCE:
rycgl
Roy Cagle
  • 1545 Answers
SOURCE: can not adjust carburetor
Yes...they have them on Ebay. Normally you won't be able to get one from a small engine repair place or dealer unless you're "in" with them. You can make using a 22 gauge-18 calibre electrical connector. (Quick disconnects-female) They need to be female spade terminals and you can stick um on the end of a screw driver and then push them down over the round-splined heads of the L and H adjusting needles on the carb. Probably have them at auto parts store....if not Radio Shack.
Posted on Jul 12, 2010
Savu Mihai
  • 211 Answers
SOURCE: Carburetor problem
Hi
High speed H=3\4 turn
Low speedL=1 1/4 turn
idle speed t adjust accordingly.
regards savumihai71
Posted on Dec 14, 2008
J. Bradshaw
  • 121 Answers
SOURCE: husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
Posted on Jun 20, 2009
Anonymous
SOURCE: Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Posted on Sep 11, 2009
michaellalib
SOURCE: how do i restring my husqvarna 125L weedeater
Take about 15' of line off the spool - join the 2 ends together to find the mid-point and hook that into the spool. Wind it around the spool - not too tight and try not to overlap the rows as you go. It is just that easy.
Posted on Jul 27, 2010
Need tool for adjusting air fuel ratio for husqvarna 235 chain saw
It should be a spline tool. It is the most common one.
Genuine Poulan Weedeater Part 530035560 Carb Adjusting Tool
If you work a lot 2 cycle trimmers and chainsaws you might buying the set of four adjustment tools.
2 Cycle Carburetor Adjustment Kit Includes 530035560
Nov 07, 2014 | Husqvarna Garden
In what order does a carburetor gasket kit go on a husqvarna 125L weed trimmer
There is only one gasket, Jenny. To figure ouut which way it goes, first put it onto the carby, then transfer it to the motor. Next put on the carby, and tighten the screws. Then hook up the electrical wiring and the fuel lines, and the job's done.
Jun 16, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
On my 125l kepps stalling out after two or three minutes
Hi ampm1947...
Sounds like you have dirt/debris in your carburetor jets or fuel passages.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
May 31, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
Husquvarna 125L Weedeater .runs great until it gets warm. I adjusted the carb screw all the way in and then out 1/8 turn at a time. No change.
Hi akabigtruck..
Sounds as if you have trash/debris in your carburetor...
Check your fuel filter if you have one, normally they are located in the fuel tank.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
This is a FREE answer,Please rate me
May 14, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
My husqvarna 125l will not start when I get it out to use it I put it on a hard surface and then I check the gas and if thats' fine then I put the choke on and prime it five times and it will not start I...
Hi chrisputten...
Try these solutions...
Check to make sure you are getting fire/spark at the plug, if so then do the following:
Check/Clean/Replace your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Apr 17, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
How do i restring my husqvarna 125L weedeater
Jul 16, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
I was using my weedeater yesterday when it killed on me, now i can't get it started. I have checked the spark plug and changed the gas ect. any suggestions on what is going on?
well, my 125l is the biggest peice of **** I ever owned... from the time I bought it, It has been nothing but a headache. By the time I get the damn thing started, I am not able to weedeat... I bought me a Stihl, Gosh, sems like I have died and went to Heaven.
Jul 18, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna 125L weedeater
The muffler may be plugged up. Wasp nest or? Take it off and look.
Al
Aug 07, 2008 | Husqvarna Sewing Machines
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
866 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
