Sanyo DS31520 31" TV Logo
Posted on Apr 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We do not have the original remote, it was broken last year. We replaced it with a Phillips Universal remote which has worked fine until recently. The tv was in video mode when the batteries were knocked out. We cannot reprogram the tv code because it is stuck in the video mode. Is there any way to get the tv out of the video mode from the back or somewhere else? Thank you for your time
Anonymous
Level 3:
President:
  • Master 2,992 Answers
  • Posted on Apr 23, 2011
Anonymous
Master
Level 3:
President:
Answers
2992
Questions
Helped
1093006
Points
9665
It shouldn't make any difference what mode the TV is in when programming the remote control. After you replace the batteries, just reprogram the control with whatever code you used before. If you didn't make a note of the code, use the remote's code search feature. That only needs the TV to be on, so that it shuts off when you find the right code. Once the remote has the right code back in it, you'll be able to switch the TV out of video mode.
1helpful
2answers
Need comcast universal remote code for DVP 3982 phillips dvd player please
Go to www.partsourceplus.com and see the list of original remotes for all types of brands.
4answers
Lost a tv remote in a fire. Bought a universal remote but cannot fine a code to program it.
read the directions at the part where it says manually program, you have to do certian functions then push the channel up and down until tv responds then its programmed, this is actually finding the code as you go, instructions will explain it all because ech universal is just a little diff in its manual process.
2answers
I lost my remote control in a recent move. Where/how can I get a replacement?
you can usually get a universal remote from most shops or on ebay if you want a original replacement try ebay again or from phillips website/ring them or a supplier
1helpful
Panasonic DMRES20 dvd recorder shows RC2 on the display and has no response. My original remote control quit working. Replaced that remote with a universal phillips. that worked fine until I changed the...
Read the manual. Using Panasonic remote hold the enter button down and #1 or #2 for at least 2 seconds until you find the right code combination for the remote and unit.
RCR312W problem
I believe the remote is losing its program. Have you tried to reprogram the remote?
Original remote for Mitsubishi CS-27EX1 tv stopped working and now after several months a replacement universal remote is unable to communicate with the tv, which works fine if the buttons below the screen...
The origional remote is no longer available. However you can get the phillips universal remote at the following link. This is one of the best universal remotes available and easiest to program and will work 3 different items. This company ships for free
http://servicemanuals.vstore.ca/
Remote does not work for TV
I assume you had new batteries in the original remote and that the Universal remote was programmed correctly for your TV.
Are there any lights on the old remote that flash when you press a button? If so, does it light?
If the TV doesn't respond to a remote, and the remote is verified to be in working order, then the infrared sensor in the TV is defective amd needs replaced.
Good Luck,
- Jim
Sylvvania 27" tv will not respond to universal remote....
it seems that there is problem with the remote receiver circuit of your tv since your remote is working alright with the other tv. inspect for possible cold solder on that circuit or failing component, but if you are not inlined with kind of job, better bring it to a qualified tv technician. good luck!
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
