SOURCE: Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Testimonial: "Thanks for the tip on the Power scan. I was trying the power scan described on some other webpage and it didn't seem to work. Your tip was dead on "
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
SOURCE: I think I set up
Hello Jdreier520, I would be more than happy to assist you but would rather do it live. Please send me an email to [email protected] so I can better assist you. You can either provide me with a contact # or I can send you my contact information so you can call me at your earliest convenience. Please note I will need model #, serial #, and TW# all located on the back of the TV as well as what you have connected to the TV and how they are connected. Looking forward to helping you get your TV running in no time.
