its usually done via the small buttons on the speedo assembly.some models like the gilera's need to be set form kmh to mph within a certain mileage or it cannot be changed the clock should be adjustable at any time.
my top speed is 150 kmh. ( 94 mph. ) I seen one from Germany his top speed was 182 kmh. don't know what he did to do that,. at 8,000 rpm that's on the speedometer, not true speed ,.I have had mine up to 8,000 rpm and only 150 kmh. he must be going down hill,. I did it only for 1/2 mile don't want to loose my lic.
Set to MPH instead of KMH its located near the reset button on left side of steering wheel. I had the same issue when i first bought this car. Hope this helps.
Anon, Remove ground on battery with ign still on to drain all power...now turn ign off, attach ground press hold lap timer button the clocks will do a cycle all way round, then the bike will flash mph kph mph kph 10 times in this time when its on mph release the lap timer button, after this bike will now read mph.
Hi Vinarbor. Just touch the middle of your screen to get to the main menu. Touch settings. Touch right arrow 3 times till you see SET UNITS in bottom right. Touch set units. You will now be able to set your units from MPH to KMH.
Push bottom button until you see TRIP in bottom left corner of screen. Then go to the back, and push the small button and hold for about 3 seconds. The WS in the top will be blinking, and the number will be blinking. Push the bottom button to scroll through until KMH is blinking. Then push the top button, to toggle to MPH. Now... you will have to rest your wheel size on this screen (the numbers) go to Sigma sports website and get the manual, then look at your wheel size on the side of the tire, put in the correct number for your wheel size. Once all this is done, then turn over and push the small button for about a second for your changes to take effect. the screen will not be blinking now.
