Question about Garden
Cub cadet rzt50 with kawasaki engine keeps flooding and dying. changed plugs fuel filter. dismantled carb and celaned throroughly. check for spark it was good. i can see gas filling up into chamber jsut below the air filter. What should i do next?
  • 3,074 Answers
Check that the choke and throttle adjustment are synced correctly. It sounds like what happens when the choke is coming on too early in the throttle application (choke applied when in the non choke full throttle start detention). I don't have the exact method without looking it up....something like this-a pin goes through a hole in the throttle bracket to line up the throttle and choke together while you make the cable adjustment. Your engine manual should give the procedure. If that doesn't take care of it then suspect worn needle and seat on the carburetor.Hope this helped Tim
Posted on Apr 24, 2011
  • 2002rex Apr 29, 2011
    thank you i will check this out =)
6ya staff
SOURCE:
2008 cub cadet rzt 50 run for 20 min than dies while mowing put new pump on, new fuel filter, new air cleaner, new plugs. has a 22hp kawasaki engine. fuel lines clear
When it stalls out did you check the spark? I suspect the engine is losing spark due to an ignition system failure.
May 17, 2017 | Cars & Trucks
IHAVE A CUB CADET 173CCOHV SELF PROPELED WON'T START NEW PLUG GAS TO THE CARB OK OK AIR FILTER OK CLEANED CARB STILL WON'T START.
got to have fuel, spark, air and compression. your missing one. be sure plug is good. give it a shot of carburetor cleaner. if it starts and dies it is fuel. check compression. take off valve cover and be sure valves are working as they should and gaped correctly.
Oct 24, 2016 | Cub Cadet Garden
Mower w/ kawasaki FR651V engine, cranks, runs 10 minutes, cuts off. Tried plugs, fuel pump & coils. whats next?
kawasaki are dirt and water sensitive chang full filter and clean carb out remove old gas from tank and clean good then refill with super unleaded gas should fun good then
Sep 20, 2014 | Cub Cadet Garden
Why does my cub cadet rzt50 sputter & die at regular mowing speed?
it is running out of gas bad needle and seat rebuild carb
Jun 28, 2014 | Cub Cadet Garden
My cub cadet will start but it will not stay running. It acts as if it isn't getting enough gas. Help!
Several things to check....air filter being clogged, fuel filter clogged, fouled spark plug, engine could be flooding--clean air filter service choke with carb cleaner-let set, throttle not opening wide enough, plugged fuel cap,
Sep 28, 2013 | Cub Cadet Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
I need an owner's manufal for a Cub Cadet RZT mower with a Kawasaki FR651 22HP engine.
http://www.google.com/url?sa=t&source=web&cd=4&ved=0CCoQFjAD&url=http%3A%2F%2Fwww.mymowerparts.com%2Fpdf%2FCub_Cadet%2FCub_Cadet_Service_and_Repair_Manuals%2FCub_Cadet_RZT_Series_Zero_Turn_Service_Repair_Manual.pdf&rct=j&q=Cub%20Cadet%20RZT%20mower%20manual%20pdf&ei=sWbITayPEoSbtweSvqmSBA&usg=AFQjCNEAreyaCVOyDN0SaP-6A0cxzha8bA&cad=rja
May 09, 2011 | Garden
My 25hp kawasakie motor cranks but wont fire. tractor model 7252. ran perfect 2 days ago. parked it now this problem. where do i start to find problem?
All internal combustion engines need three things to operate (air, heat or spark, fuel). Check to see if you have all of these things, a clean air filter with a clear path to the carburetor, spark at the end of the plug wire (this can be checked by using a screwdriver inserted into the plug wire end and holding it close to a metal grounded surface), and fuel to the carburetor (check to see if you have fuel at the fuel line going into the carb or an easier test is to spray a small ammount of carb cleaner into the throat of the carb just before cranking, if it starts and runs you have a fuel supply problem then check backwards to find the blockage (pinched fuel line, plugged fuel filter, bad fuel pump ect).
If no spark at the plug wire check all connections at electrical terminals under hood and at switches for parking brake, belt engagment (PTO) ect..
Usually if something runs and then just dies suddenly there is an obvious problem, your powers of observation will help you the most. Look at anything that looks out of place.
Jan 25, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub ztr 50'' with 22 hp Briggs. PROBLEM: Engine dies with or without deck engaged! I replaced fuel pump, fuel filter, plugs,and cleaned air filter. Could my problem be a (sometimes good / sometimes bad)...
Need more info...
When it dies, does it crank back up? if not, at this time, you could check for spark. If none, you might be on track with a fault in a switch.
But if you have spark and it doesn't crank,
check for condesation in the gas (carburator and fuel tank). If any, problem solved... drain and dry carb bowl and gas tank to insure all trace of water is out.
Hope this helps... Good luck!
Sep 12, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
460 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
