Calls are signalled in two ways. First, check the Ringer switch on the left side of the phone. It's a 3 position switch OFF/LO/HI. If the outside lines are blinking the MESSAGE light, then the ringer is probably turned off. If your intercom calls are toning but not ringing, you may have the AUTO ANS light lit. Press it until it's off and intercom calls will either start ringing or send an audible tone.
If it tones, then you have a programming problem where intercom calls are set to tone instead of ring. That's corrected in system programming.
Carl
Dear Carl,
Thanks for your reply, the model I used do not have the AUTO ANS light lit. May I know how to set intercom calls to ring.
Thank you!
This could be your lucky day. From the idle phone press PROGRAM and dial 41 STORE.
That's the command set for a TA series system. Your 77xx series phone works on about 18 different Panasonic phone systems. This command will work for about 3 or 4.
Carl
Yay. Please take the time to rate my solution. Thanks. I'm happy it worked for you. BTW Program 42 STORE puts it back to the other mode.
Dear Carl,
It is my lucky day to have it fixed. Thank you very much!
